Look for about 70amp, and wire them through relays. Looks a really nice car
Spots on MK1
- Been thanked: 7 times
Re: Spots on MK1
Best option for output (for sensible money) would be this:
but won't look very period.
You might find a 45A 17ACR style which will look a bit older. Depends on what your use will be and the wattage you intend to run, but 45A might be OK (be better than a dynamo anyway!)
- Has thanked: 7 times
- Been thanked: 6 times
Re: Spots on MK1
thx, the connection is for September. This month I don't have the time, lot of work and hopefully on holiday with the mini the end of the month
MK1 Austin Cooper 998cc 1967 Smoke Grey
http://mk1-forum.net/viewtopic.php?f=6&t=26813
- smithyrc30
Re: Spots on MK1
Not 100% sure but I thought the Lucas 17ACR was the 45A RHS version, the 18ACR bring the 45A LHS variant. It affects the front bearing housing so the alternator could hang off the LHS or RHS when looking at the front of the engine. The A series needs a LHS mount.GraemeC wrote: ↑Fri Aug 07, 2020 8:09 am Best option for output (for sensible money) would be this:
The housings are the same except the position of the tapped hole for the adjustment strap and the clearance hole for the securing bolt. It is possible to undo the casing bolts to rotate the cases 120 degrees but then you need to fit a bolt and nut to the adjustment strap at the alternator and either drill out the upper bolt hole or screw the securing bolt directly to it. If I recall the thread was 5/16 UNC.
Re: Spots on MK1
I thought the 16, 17 and 18 ACR units were all available LH or RH - the difference being the output (16 = 34A, 17 = 36A and 18 = 45A)?
I just tend to call them all 'generically' a 17ACR as that seems to be the most recognised.
- LarryLebel
Re: Spots on MK1
LR8's and a Roo bar.
- LarryLebel
Re: Spots on MK1
North Vancouver. The spots are mounted at the licence plate brackets for stability using DIY mounting brackets made from 2 layers of 1/4" steel to keep them from shaking. I used to have LR9's but they wouldn't fit with the 'roo bar. I love my 'roo bar.
- LarryLebel
