Choke position
johnv
Choke position
Post by johnv »
Parnell shows the choke in his mk1 cars on the right, and on the left in the Mk2 cars. Is this correct? AFAIK they are all RHD cars.
Mk2 1968 Cooper 998 TPL555F
Mk1 1965 Cooper 1275 BFC110C
'S'-type
Has thanked: 39 times
Been thanked: 15 times
Re: Choke position
Post by 'S'-type »
My mark 1 has the choke on the right. ( Could have been changed at some point so no guarantee it's right. ) Mark 1 driver's handbook has it on the right.
I think on later models it may have depended on what type of heater was fitted. Also saloon/commercial differences.
As so often is the case there are probably exceptions, but as a rule of thumb it seems right side is 'correct' on the mk1 Cooper.
EMOKID
Re: Choke position
Post by EMOKID »
I think Parnell's book mentions changeover of positions on mark 2 with the intro of the soft feel type choke / heater controls.
floormanager
Has thanked: 23 times
Re: Choke position
Post by floormanager »
My Jan '68 MK2 has the choke on the right.
abs
Re: Choke position
Post by abs »
My December 67 mk2 has the choke on the right, I often pull the heater by accident.
ricardo
Re: Choke position
Post by ricardo »
In Mk1 cars, LHD or RHD doesn't matter, they all were in the same position, heater on the left, choke on the right.
snoopy64
Has thanked: 88 times
Been thanked: 14 times
Re: Choke position
Post by snoopy64 »
EMOKID wrote: Thu Jul 02, 2020 4:39 pm I think Parnell's book mentions changeover of positions on mark 2 with the intro of the soft feel type choke / heater controls.
Yep, my 69 plastic heater mk2 conforms that
Kevin
InnoCooperExport
Has thanked: 4 times
Been thanked: 9 times
Re: Choke position
Post by InnoCooperExport »
ricardo wrote: Fri Jul 03, 2020 6:31 pm In Mk1 cars, LHD or RHD doesn't matter, they all were in the same position, heater on the left, choke on the right.
Another Mk1 feature retained by Innocenti. Despite all cars being LHD the choke is always on the right, right through until production ended in 1975.
dodge44
Re: Choke position
Post by dodge44 »
[Question moved elsewhere]
rogerotto66s
Re: Choke position
Post by rogerotto66s »
The choke was always near the driver and the heater away from the driver. So... LHD was opposite of RHD.
Here is what Parnell had to say.
Roger Williams
ricardo
Re: Choke position
Post by ricardo »
rogerotto66s wrote: Sat Aug 01, 2020 2:04 pm The choke was always near the driver and the heater away from the driver. So... LHD was opposite of RHD.
I'm not sure if that's correct, but it might be true for some markets. Not all of them for sure.
And that can only be applicable to Coopers, a panel for a heater rheostat switch will never allow the choke cable to be fitted on the left.
