Anybody happen to know what the psi rating for the hydrostatic
lines is? I'm thinking of putting in braided stainless line thats
rated at 1500 Psi
Kent
PSI rating for hydrostatic lines
- 65MK1S
- Andrew1967
Re: PSI rating for hydrostatic lines
Normal operating pressure is around 280 psi, so I think your lines would be more than adequate Kent
- Has thanked: 188 times
- Been thanked: 66 times
I was just trying to find the article, but I have a recollection that the flex lines to the Bags have a rating of 2000 PSI.
While Andrew's correct that the (static) pressure is of the order of 280 PSI, in use, it's not uncommon for it to go to 1200 PSI.
- Andrew1967
Good point Chris, hadn't given operating pressures a thought.
Is that 1500 psi operating or burst pressure Kent ? If operating then I'd have thought they'd be fine as burst is normally several times higher than operating.
- 65MK1S
Thanks for info guys, I'll check on the burst pressure vs operating pressure.
Kent
Kent
- 65MK1S
It looks like the stainless hose has 1500 psi working pressure
Kent
Kent
