Remote Diff housings
Has thanked: 189 times
Been thanked: 68 times
Re: Remote Diff housings
251 ENG wrote: Sun Jun 28, 2020 3:13 pm Spider , where to you get the diff centre size of 4.000" - 4.003' from ?
I don't recall off hand what the center size of the diff is and I'm sure I haven't mentioned that in this thread. I have mentioned the center to center distance though, is that what you are referring to ?
251 ENG
Post by 251 ENG »
Yes that's it
I have a factory table of the gears from the early boxes, that has the gear specs in it, including the PC Diameters of them,
251 ENG
Post by 251 ENG »
That's spot on , thanks
251 ENG
Post by 251 ENG »
Is they a factory size and tolerance for diff bearing bore ?
agricola
Post by agricola »
You will be dictated by the bearing so bearing suppliers should give you that
