Switch Cooper MK1
WesleyB
Has thanked: 7 times
Switch Cooper MK1
Post by WesleyB »
Hi,
on cooper s you find longs switch.
I have a extensions on the switch, but this is plastic and not really good. To flexible
Where can I find a long switch ? Do this exists ?
MK1 Austin Cooper 998cc 1967 Smoke Grey
http://mk1-forum.net/viewtopic.php?f=6&t=26813
whistler
Has thanked: 18 times
Re: Switch Cooper MK1
Post by whistler »
These were aftermarket switch extenders, used on lights and wiper switches. The only long switches I saw back then were ones used for air horns or headlight/spots flasher. They weren't on/off switches if I remember correctly.
AndyPen
Been thanked: 51 times
Post by AndyPen »
I've seen a motorsport car with the entire switch plate extended forward with two brackets so that you can reach the switches - may be from the later padded parcel shelf or something?
What you have there is pretty much what we all used back in the day though.
olddave
Been thanked: 12 times
Post by olddave »
They are better in the cooler weather!
WesleyB
Post by WesleyB »
Thx for the replays.
Indeed in warm weather it's to flexible.
I was think that there was a other option, but now I know it with the replays, thx
whistler
Post by whistler »
There are more than 1 manufacturer/type. The ones I've sold were more square in section and the end was angled for finger press. Could have been Stadium, B&G, Paddy Hopkirk etc.
zootmini
Post by zootmini »
Hi Wesley,
I am from Brussels, give me your adress and I will sent you a pair off switch extender for free, or if you want to see an other Cooper fanatic you may come to Brussels and have a drink !
Kind regards, Chris ( Zootmini ).
zootmini
Post by zootmini »
Hello wesley,
Receive a message from you in my mailbox who says to read it in "mk1-forum-net", but cannot open it ! What is "mk-forum-net", and how to use it ? Maybe you can contact me directly ! Sorry for my frenglish !!!!
Kind regards, Chris.
zootmini
Post by zootmini »
Rehello Wesley,
Finally find your message ! Thank you.
Kevin-mini
Post by Kevin-mini »
There are many type of switch extensions and,
the one you have is softest :)
Kevin-mini
And these:
