Pressed Steel Rocker - re-bushing help!
moita
Post by moita »
Hi,
I have succefully taken off all bushes from pressed steel rockers (850).
I have found that I need to pre-drill oil holes before fit again the bush, my question is:
- Where do I do this 3 mm hole?
The original bushes are different from new ones. Where is the screw drivers is where the hole is, and I place a bearing outside in same position.
Can anyone help me?
Thank you.
Vegard
Re: Pressed Steel Rocker - re-bushing help!
Post by Vegard »
You don't need to drill the bushes. Where is the oil suppose to go? Only the S rockers had an oilway to the adjuster screw. I guess they just used the same bush at the factory.
moita
Post by moita »
Great, even easier :) and the internal shape, should I care about its position?
Hipwell
Post by Hipwell »
I was under the impression, maybe wrong, that oil weeps through the rockers.
cooper64
Post by cooper64 »
the oil should get to the adjuster screw and run down the thread to lube ball and pushrod ,that is why there is a hole in it and with cast rockers must be drilled from screw adjuster end of rocker to bush then outer hole filled in end of rocker
Polarsilver
Has thanked: 38 times
Been thanked: 52 times
Post by Polarsilver »
Sorry this is Off the Post subject..can i ask a Question ..are these aftermarket Roller Rockers also drilled with an oilway so as oil reaches the Pushrod Cup ?
GraemeC
Been thanked: 7 times
Post by GraemeC »
Yes.
Or at least the MED one I have in front of me is:
moita
Post by moita »
Thank you all for the answer so far. :)
