Length of longest cross joint drive shaft
- goff
Anybody know the length of the long drive shaft ??? , Cross joint one, i have one that i was going to replace it with , BUT it is about 13 mm longer , it measures aprox 402mm , i guess it is 1100 ADO 16 ,
Goff
Goff
- CMC
Re: Length of longest cross joint drive shaft
Here you see the difference between Mini shafts (the left pair) and ADO16 shafts, both rubber cross, with the measuring tape on the ADO shafts.
- goff
Thanks CMC , So the ADO 16 is about 393mm that is what have taken out
, i have a mini long drive shaft that measures around 403mm ???? , is that correct CMC , Thanks again for taking the trouble to dig them out and measure
Goff
Goff
- CMC
Sorry Goff, I wasn't clear enough. The 393 mm is the short ADO shaft. 402 mm is the long Mini shaft.
I compared these last year after gambling whether the short ADO shaft was usable as a long Mini shaft. Eventually I bought a pair of Mini shafts.
- goff
Thanks again CMC , Yes somebody sold me a ADO16 short shaft for a mini , it has been in 6 years and done 5,000 miles , everything was new ball joints , 71/2 disc brakes ect ,wheels balanced ect , But always shook the steering wheel from 55mph upwards , trying to get to the bottom it !!!! , i hope now it will be cured, having changed wheels , complete hubs ect , Maybe that 10mm short was just enough to make the drive shaft wobble in the yoke
, I got to thinking that one shaft was bent !!! that is why i started to replace them today and obvious when i put this one next to the replacement noticed one was longer . Thanks again for taking the time CMC.
Regards
Goff
Regards
Goff
- Has thanked: 188 times
- Been thanked: 67 times
Goff, I've not measured them, but the Cooper S / Auto Shafts that use the Hardie Spicer Joints are a little longer than those that take the Rubber Joints, it would be around 1/2" difference between them mate
- Been thanked: 52 times
It's the other way around Spider, the Hardy Spicer shafts are shorter. although if you are running negative camber l can't see a problem using the standard shafts.
- goff
Good info from all , Great this forum , Thanks again lads .
Goff
Goff
I have been using pot joint shafts mostly for the last number of years. I still have a collection of cross joint axles.
All I'm sure of is I only have one set of them with the raised area as pointed out in a pic. I may be wrong but always
figured these are Cooper S axles. Of course there were cross joint axles in S cars but I'm not sure if those axles had
the raised area. Steve (CTR)
