Hi all,
Grateful if one of you with an encyclopedic parts knowledge (!) can advise; having a rummage in the loft I came across two boxed sets of Unipart GHK1804 which I think are Mini/Metro rear wheel fitment. They’re Timken taper roller bearings, the bearing race being Timken NP548549 - are these Mini fitment?
Rear wheel bearings
- Has thanked: 189 times
- Been thanked: 68 times
Re: Rear wheel bearings
Under that Part Number, it came up as a Rear Wheel Bearing set for an Inno Mini.
I don't know if they had a different wheel bearing set to any other Mini - I thought they would have been the same, and I'd say, likely it.
Didn't regular Mini's run ball bearings back and front, and, S models had the Timkens?????
Either way, should work fine on any Mini.....
Yes, if they’re right, they’re going on a cooper s project. However wanted to confirm.
