hydrolastic to dry
kevs 1961 mk1
hydrolastic to dry
Post by kevs 1961 mk1 »
hi all ive a 61 morris mk1 that im starting on , the front subframe is in rough condition ,I have also a very good hydrolastic front subframe ,how easy is it to convert it to dry , I know you have to flatten or grind off the locating lugs for the displacer units but is that all or are the top arms needing swapped out as well cheers in advance for any help with this
long time gone
whistler
Has thanked: 18 times
Re: hydrolastic to dry
Post by whistler »
You're going to devalue the car if you fit a hydro subframe as they weren't introduced until around 1965.
kevs 1961 mk1
it aint gona be totally original anyway mate just a very good usable car
long time gone
Has thanked: 189 times
Been thanked: 70 times
The Top Arms are different. You can use the Hydro Arms, but it will be a much harder ride.
You'll also need to run Hilos as the Towers on the wet frames are 1/4" taller.
If you do run with the Hydro ones, the hole that currently holds the bump stop in place needs to be drilled to 3/8" clearance for a Shocker Bolt.
kevs 1961 mk1
Spider wrote: Thu May 28, 2020 6:15 pm The Top Arms are different. You can use the Hydro Arms, but it will be a much harder ride.
cheers mate thanks for the info il probably use the dry arms and run hilos front and back
long time gone
TECH396
Post by TECH396 »
Don't forget the shock mounts on the body, as well as new, dry upper arms.
Paul H.
snoopy64
Has thanked: 88 times
Been thanked: 14 times
Post by snoopy64 »
Good hydro front subframes are hard to come by... sell it and buy a dry one! :)
Kevin
Andrew1967
Post by Andrew1967 »
snoopy64 wrote: Fri May 29, 2020 11:39 am Good hydro front subframes are hard to come by... sell it and buy a dry one! :)
That was my thoughts too.
kevs 1961 mk1
Andrew1967 wrote: Fri May 29, 2020 1:26 pm
might do its in excellent condition ,freshly powdercoated too ,Image
long time gone
snoopy64
Post by snoopy64 »
When i needed one 5 years ago it took ages to find one... everyone says oh the front ones never go 'cos they are covered in oil... well i took mine off and when it was blasted it was very thin in places and had a couple of patches!!!
Kevin
AndyPen
Been thanked: 51 times
Post by AndyPen »
Certainly be a shame to hack a nice hydro like that up :?
bwaminispeed
Post by bwaminispeed »
Of course, you could just install the wet subframe, and, leave it wet (supposing it still has the hydrobags in it)......
They don't have to connected to rear ones, you can just pump them up separately........
I once spliced the front end of a wet MKII Mini to the back half of a MKI wagon, and, just pumped the hydrobags up, made it easy to adjust front ride hight, drove real nice that way.......
