Amongst some of the rads I picked up yesterday is one stamped ARA1980 and dated 6 65
The rest are either ARA1573 or ARA2063
Anyone able to identify the radiator by the number ?
cheers
Andrew
ARA1980 radiator
- Andrew1967
- Andrew1967
- LDR209H
Re: ARA1980 radiator
With the early rads Andrew,it's easy to spot a Cooper 'S' one from 850 as the bottom hose flange is angled 45 degrees to clear the larger front pulley damper.
So what was it that you hoped for?Andrew1967 wrote: ↑Sun May 22, 2016 11:32 am Checked the AKD parts manual and it is what I hoped it might be![]()
- Andrew1967
I’ll have to have a look at it to double check but I think I worked out that it was the original radiator out of my March 65 S. Not just by date etc but also by the silver paint it was covered in as was the engine bay of the car !
It wasn’t in the car when I got it but was subsequently discovered in an Austin 1100 full of Mini and ADO16 radiators elsewhere at the parts department.
