Minispares 1.5 forged rockers
- Been thanked: 22 times
Hello chaps.
I’ve just fitted some minispares forged rocker arms to my 1275GT engine (1805 head) the push rods are hard against the front of the rocker tubes in the head casting ..
Any ideas where I’ve gone wrong?
Re: Minispares 1.5 forged rockers
Are you using standard non modified rocker shaft pillars? If so you have to open the stud holes and move them back. To get the increased ratio the push rod arm of the rocker is shorter and the valve end longer, so things need repositioning.
So machine the stud holes in the std posts? I’ll have to move them a good 3mm ?
That will affect the oil feed?
So should I just buy the rocker assembly C-ATH436?
Is this just bolt on?
Any other options?
Any other options?
You need push rod clearance on the push rod bore at full lift. As to oil way clearance, if that is in doubt it is simply a matter of grinding out a groove in the rocker pedestal to align with the oil feed.kit of bits wrote: ↑Sat May 16, 2020 7:48 pm So machine the stud holes in the std posts? I’ll have to move them a good 3mm ?
If in doubt fit the full kit.
Rolandino on here offered me a set of 1.5 forged rockers the other day . See my wanted add , his link was on there .
8662 FN Austin Mini
Yes I know it’s not original
My wife says I don’t listen to her or something like that !
If you have access to a good machinist he can built you a proper set of pedestals, i could provide you the sizing/measurements on the Minispares 1.5 pedestals, but only next weekend
cheers
Luis
cheers
Luis
Thanks he’s off at the mo..
I’m thinking about going the Calver route, even though I said never again last time ah and the time before that..
- Exminiman
- Has thanked: 54 times
- Been thanked: 52 times
Swiftune do similar, might be same one https://swiftune.com/parts-shop/cylinde ... embly.htmlkit of bits wrote: ↑Sun May 17, 2020 6:51 pm Thanks he’s off at the mo..
- Been thanked: 7 times
Same but more expensive!
Think Calver supplies them.
They are a nice bit of kit.
I'm pretty sure the Swiftune ones are supplied by Calver. They are actually slightly cheaper from Swiftune - £295 +VAT compared to CalverST at £299.50 +VAT. The CalverST website only shows ex-VAT prices. It's a bit academic though as Swiftune are out of stock!
JR
JR
- Hipwell
- Been thanked: 3 times
They are the same, was tempted but hear(From mini engine builder) the pads are not heat treated and suffer pretty bad wear, anybody else seen this?
- Been thanked: 10 times
I have used 3 sets of Keith's 1.4 rockers & have been VERY pleased with them. No sign of any appreciable pad wear apart from on one rocker that turned out to be slightly nipped to begin with.
Minisport! that will explain the quality then, this is how my last 2 sets arrived from KC.
Yes arrived!
Yes arrived!
Goodness me! That's not great.
I don't know if it is a new innovation that these rockers are supplied by MiniSport. But I have seen a whole pallet of raw rockers in Keith's old unit at Malton before now. Maybe things have changed since he has moved down to Norfolk.
I remember him posting that his old supplier gave him an 'option' of either paying considerably more or they would farm out the production to China. Not sure what the outcome was.
Was MiniSport that old supplier? Or are they who he has turned to for alternative production?
- Exminiman
Ditto, thought I remembered something also.....this might be itGraemeC wrote: ↑Thu May 21, 2020 8:58 am I remember him posting that his old supplier gave him an 'option' of either paying considerably more or they would farm out the production to China. Not sure what the outcome was.
EDIT, off Facebook...
