Taking Out the Front Screen..
DB1380
Post by DB1380 »
Hi all, hope everyone is keeping well in this madness. Just a quick one....
Is it possible to take out a Front Windscreen without ruining or cutting the Rubber Seal so it can be re-used ? :shock:
Cheers. Dicky.
Cheers Dicky.
KPB 729C 65 Mini Minor 1380
GraemeC
Been thanked: 7 times
Re: Taking Out the Front Screen..
Post by GraemeC »
Perfectly possible, but if the rubber is old then chances are it won't seal again very well (that is if it doesn't crack/split)
Polarsilver
Has thanked: 38 times
Been thanked: 52 times
Post by Polarsilver »
Cut the original seal... there will be regret If you Bust the Windscreen while trying to save the Seal :cry:
Daz1968
Post by Daz1968 »
I have removed screen a few times without damaging seal, once chrome trim is removed it pushes out quite easy if starting from a corner.
Has thanked: 246 times
Been thanked: 221 times
Laminated windscreens are much easier to crack than toughened.....if you put too much pressure in the wrong place.
swifty
Been thanked: 34 times
Post by swifty »
If your not going to cut the rubber then the best way is to sit between both seats and put your your feet at equal distance apart on the screen and gently push with someone catching it on the other side if need be ..... ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
Time Bandit
Post by Time Bandit »
swifty wrote: Wed Apr 22, 2020 8:55 pm If your not going to cut the rubber then the best way is to sit between both seats and put your your feet at equal distance apart on the screen and gently push with someone catching it on the other side if need be ..... ken
Yep, I did mine like that many years ago, worked perfect and my nice and fairly new laminated screen came out undamaged. I then bust the bugger trying to put it back in though... :( :(
Mike
DB1380
Post by DB1380 »
Thanks for the replies.
Reason i asked....The screen i have in now is not very good, full of scratches some quite nasty.
I have another screen to go in, so im not too fussed about the old one.
The Rubber Seal is in really good condition and at least i know it will fit.
May give it a go. Ill keep you updated.
Dicky.
Cheers Dicky.
Highnumbers
Post by Highnumbers »
Careful!
I'm ashamed to admit I cracked the original laminated windscreen on my Cooper S while disassembling the car for a restoration. It had been in perfect shape for 50 years, and I ruined it... :cry:
