Powder Coat Removal
- Has thanked: 10 times
Powder Coat Removal
I’ve got to remove some powder coat from a couple of finned alloy rocker covers. Are there any paint removers that will do the trick?
- 65MK1S
Re: Powder Coat Removal
I think a rotor hammer would be your best bet
IF the powder coating is
done correctly, the powder coating literally seeps into the open pores of
the metal when it gets hot. My condolences
- Has thanked: 18 times
- Been thanked: 51 times
On my Cosworth arms I softened it with some thinners and scraped - but nowhere near a fiddle as what you've got to sort I'm afraid.Having said that, I have a set of dental scrapers and the corner bits popped out easier to my surprise.
The blowtorch did come out too!!!
Good luck
Good luck
Thanks. I was really hoping someone would say “put this stuff on and it peels right off”.
I use mops but I have a polishing machine they may fit on a drill but you need to hold everything secure and wear goggles and mask.
https://www.thepolishingshop.co.uk/sati ... ops&page=2
- Has thanked: 189 times
- Been thanked: 68 times
Apart from the chipped bits! It’s a right pain because they’re quite nicely done.
- Hipwell
- Been thanked: 3 times
Starchem Synstryp works if you have the time. Did some parts today but the power coating was very thin.
