1980 / 90's Mini Racing Photos
Re: 1980's Mini Racing Photos
Swiftune powered Rallycross Mini at Brands approaching Druids, I think the year was 1986. One of my earliest snaps with my Olympus OM10.
- mab01uk
- Has thanked: 191 times
- Been thanked: 147 times
Article below from Motorsport Magazine - Page 46, August 1992
Small Is Beautiful
You know that Copse is quick, always have known it. And it became more of a challenge a few years ago, when they did away with the Silverstone short circuit beloved of slipstreaming Formula Fords (remember them arriving several abreast at the old Woodcote?), and added a few new fiddly bits suited to greater purity of racing line than the old who-can-be-last-on-the-brakes right-hander. The upshot is that the straight leading to Copse is now longer, approach speeds are higher and Silverstone's first corner has become more of a trap for the unwary.
In a Mini Seven, however, the level of commitment seems not to matter greatly. There always seem to be a few inches of track left that you could have utilised. And you don't so much steer a Mini Seven into Copse. You throw it. In too fast? Simple. Ease the throttle, and the rear end begins to break away ever so gently. It feels as though you have all the time in the world to correct the ensuing slide via a steering wheel which wouldn't look out of place in a Routemaster bus. During the relative calm of a midweek test session, it's worth lifting off at Copse just for the hell of it, make sure you weren't imagining it. Can a frontwheel drive car with such a tiny wheelbase really be so responsive, so progressive, so easy to manipulate via the throttle?
Time after time, you get the same answer.
Yes.
The car in question is Steve Bell's. Beautifully turned out in the colours of sponsor Wood & Pickett, it may be a close relation to the Mini Seven racers of the '70s in terms of technical presentation (although the previously specified 850 cc engine was junked at the end of 1990, in favour of a one-litre unit), but bodily it looks nothing like its forebears. The days of the scruffy Seven, wearing faded, battle-scarred BL paint and looking largely standard apart from the absence of wheel trims and emptiness of the ashtray have long gone. Mini Seven racing, originally the brainchild of the 750MC, which was looking to provide a cheap alternative to special saloon racing in the mid-'60s, is now into its 26th season. Nowadays, the series has official Rover support and the standard of car preparation is, generally speaking, absolutely superb. Bell's Mini, like those of most of his rivals, looks more suited to a concours than a 10-lap thrash around a muddy, wet Cadwell Park.
Despite the increased commitment to immaculate presentation, the Mini Seven series and its more powerful Mini Miglia cousin - of which more anon - remain relatively cost-effective in this day and age. Rover blessing, Unipart sponsorship and administrative assistance from the BRDC (which brings support race status at BTCC and British F3 rounds) help in this respect, of course, but a competitive Seven could cost anything between £2,500-£4,500, the cost likely to vary according to individual technical ability and the quality of finish you are looking for in the end product. On top of that, Bell in his second season of Seven racing, although he's been around for a lot longer, usually wielding spanners for friends estimates that a 12-race season absorbs about £2,500 in running costs. Despite the car's propensity to slide around at the driver's whim, Bell got through just two full sets of Dunlop control tyres in 1991.There are only two tyre choices available - wet and dry, though the slicks are treaded - and Bell simply shifts the rubber from corner to corner during the year, according to rate of wear. "It represents value for money," believes Bell. "It's a good series, with close racing right down the field, and there's excellent camaraderie amongst the drivers." The latter aspect is not to be overlooked, either, in an age when suspicions about rivals' 'unfair' technical advantages are unhappily rife at many levels of the sport. Mini racing is happily devoid of protests.
The engine is almost fully race-prepared. The pistons are standard, balancing apart, and the head is pretty similar to that on a Miglia, albeit mildly strangled by the compulsory fitment of a 1.5 in restrictor plate. The camshaft is nicked from an MG Metro, and fuel is distributed via a single-choke carburettor, usually a 45 DCOE Weber with the jets soldered on one side. Maximum power, reckoned to lie somewhere between 70-80 bhp at the wheels, is delivered at 7400 rpm, although the engine will tolerate a few hundred revs more before the valves pogo through the bonnet. To maintain momentum, you need to keep the engine thrashing around between 6000 rpm and the aforementioned power peak.
The cacophonous result makes a pneumatic drill sound like a milk float, the aural assault amplified when the characteristic Mini transmission whine chimes in on backing vocals. Unfortunately, the transmission was more than just noisy on the day of our test. It was also a shade uncooperative. Bell warned that it was baulking at the change down from third to second for reasons unknown, which turned both Becketts and the complex running from Brooklands to Luffield into hit and miss affairs. The theory is that you turn in in second, feather the throttle (plant it too early, and you'll simply exit stage left in a frenzy of understeer) and get back hard on the power once the nose is firmly on course for the apex. The reality, on this particular day, was that you sailed into both corners thinking you were in second.
Leastways, I did.
Neutral is neither tractive nor accelerative; eventually, caution prevailed and both corners were taken in third, which completely wiped out any sensation of what either is really like. Copse, though, was worth waiting for, and brought back happy memories of being bounced around Mallory Park in a Seven some years ago, whilst conducting a similar exercise for Motoring News.
Trying to find one adjective to epitomise Seven racing is tricky.
Noisy? Not strong enough.
Bloody noisy, then? Accurate, but doesn't really convey what Sevens are like.
The most apposite description is probably 'moreish', although 'profitable' also springs to mind if you are any good at it. The combined Seven/Miglia prize fund is £13,000, and includes a road-going Mini Cooper for the driver with the highest overall points total in either series. For the past two seasons, Bill Sollis has outscored the Miglia champion in winning the Seven series outright, and has thus become the proud owner of two Coopers, albeit briefly. The Westerham fireman has sold on his prize on each occasion, the resulting income being put towards the subsequent racing campaign. This year, Sollis has used the assets accrued from trading in his Cooper prize for a season in Mini Miglia (a slightly fresher initiative, as it's only in its 22nd season...), which is less restrictive under the bonnet, although it shares many of the Seven's chassis and bodywork regulations (silhouettes must be kept standard, although lightening of subframes and other subtleties are permissible). Consequently, the Miglia is a costlier option than a Seven.
At Silverstone, we tried the front-running car of Richard Wager, which its proprietor felt still needed a little fine-tuning at this early point in the season. Wager is one of those who does much of the labour himself; by his assessment, a competitive car can be built — or bought — for around £5000, and running costs for the season are likely to be as much again.
Tyres, reckons Wager, are "expensive", for what they are, but like Seven counterpart Bell he reckons he can get by on eight per season. Again, control Dunlops are mandatory, and these must have at least 1.6 mm of tread at the start of a practice session or a race. Three compounds are available, and Wager uses a pick'n'mix selection: the softest at the rear, medium front right and hardest front left.
There are immediately obvious similarities between Sevens and Miglias, notably in the superb standards of presentation. Wager's car, like Bell's, was unblemished by grime. A Miglia field looks like a half-scale replica of the BTCC, thanks to commendable pride on the part of enthusiastic owner-drivers and not a little elbow grease.
And there are equally apparent differences. Although the Miglia just tops 100 bhp, the four-seconds-per-lap difference around Silverstone's 'national' circuit owes as much to greater braking efficiency and superior grip as it does to grunt. With a drag co-efficient similar to that of Ben Nevis, there are limits to how quickly a Mini will go in a straight line, even with the engine zinging along close to 8000 rpm in fourth (i.e. top) on the approach to Copse.
Where you throw a Seven into corner, a Miglia demands considerably greater precision. When the Dunlops lose grip, the Miglia breaks into more of a fidget than a slide. It's nothing like as progressive as its junior cousin, nor does it feel as tolerant of gorillaesque driving tactics. Nor, when it comes down to it, does it have the Seven's grin factor. It requires an altogether gentler, technically purer approach, though competitive Seven graduates such as Sollis have proved that it doesn't take long to master the Miglia technique. At the time of writing, Bill was third in the Miglia series. In touch, though not quite the required form to win a third straight Mini Cooper...
If there had to be any gearbox problems on the day, it was a shame that they struck the 'wrong' car. The Miglia has considerably greater torque, and third gear is fine for the tighter sections.
As this issue of MOTOR SPORT goes to press, there are four rounds of each championship still to run, at Snetterton (August 1/2), Mallory Park (August 23), Silverstone (August 31) and, lastly, Donington Park GP circuit (September 19/20).
After all these years, the Mini is still a source of some of the best circuit racing in the UK. Despite the proliferation of one-make alternatives, which grow by the year, the level of support for Mini racing, Seven or Miglia, has never once declined.
Its enduring popularity in these times of apparent recession isn't difficult to pinpoint. In the overall scheme of things, it is reasonably priced. It is as much fun to watch as it is to participate, and the paddock retains the happy-go-lucky flavour of the '60s, when the concept was originally launched.
Mini racers are as friendly a bunch as one could wish to meet. More power to their elbow grease.
SA
https://www.motorsportmagazine.com/arch ... -beautiful
- mab01uk
![Image](https://i.imgur.com/iexm9kD.jpg)
(Photo: Andrew Kitson)
Barry Reece 850 Mini - Silverstone 1980.
https://tentenths.com/forum/showthread. ... 215&page=4
- minimans
Hi Tim, where and when was your shop in putney? i grew up in Putney. do you remeber a Andy Judge who had a shop onWoodlands Way?Tim Harber wrote:Had some of these tyres through my hands when I had the shop in Putney. From? To? .......Pass
May have been round about the time that Marc LeMaitre built up his car
- mab01uk
"Another Mini below running Tyrrell 6-wheeler tyres and, as it happens for this picture, a Chris Tyrrell head."mab01uk wrote: Interesting arches on this Clubman.....Driver: Pete Daniels, his teamate in the matching 1275GT/Clubman behind started on pole position (see grid photo below).
A guy on the Miniforum who goes by the user name 'Oldskoolcool' posted this (in 2014) about the two Minis in my photos above............
'I can shed a bit more light on the subject.The Clubman with the big arches was built by my father (Peter Hill), it was raced by himself from 1975 to 1978.
It originally was a Mini miglia (998). In 1977 he was able to obtain some set of tyres from the Tyrell 6 wheeled F1 car .
These were fitted to 8x10 Mamba solar 3 piece split rim wheels .The front brakes were also from the Tyrrell, these were huge vented discs that were x-drilled and pegged with copper rods. The calipers were modified alloy F3 GR units with Cortina brake pads. Probably the first vented disc set up inside 10s.
The arches were hand made and were originally polished alloy and looked a hell of a lot better! He only ever raced the car once with those arches on, as the scrutineers were not very impressed. He sold the car in 1978 to build a brand new Miglia. The other Clubman was his brothers (Charles Hill) old Miglia that was also running with the Tyrell tyre set up'............
Brands Hatch, March 1978
https://tentenths.com/forum/showpost.ph ... stcount=37
![Image](https://i.imgur.com/voivrfk.jpg)
(Photo: Greg UK)
These wide low profile 10" tyres were as used on the 6-wheel Tyrrell F1 car:-
"Tyre manufacturer Goodyear, then the sole supplier to F1, agreed to produce the required 10-inch rubber for the Tyrrell P34.
The main problem for the car was the front tyres, whilst Goodyear developed the rear and the standard sized front F1 tyres throughout the 1976 season, development of the bespoke P34 10" tyres was sadly lacking. Access to the tyre testing machines was limited to one plant in Belgium and only then on certain nights in the week, by the end of the season the P34's front tyres were almost six months behind in development compared to the rears."
http://www.project34.co.uk/index.php/te ... ifferent-3
- mab01uk
Jim Dineen the son of Neil Dineen is doing a search for old photos for an upcoming birthday. If anyone has any other photos of him or Pete Crouch and / or the car they would be most welcome.mab01uk wrote: ↑Sun Jan 22, 2017 11:41 pmI posted these photos on the Ten Tenths Motorsport forum some time back and a recent reply from Mike Parker as quoted below has added some interesting info on the Longman built 850cc short stroke engine as used by Neal Dineen and Peter Crouch:-
"Hi there
My name is Mike Parker. I was racing in the late 60's/ early 70's. Triplex, Osram GEC special saloon car chmpionships etc etc.The longman short stroke engine that was used by Neal Dineen and Peter Crouch was in fact my short stroke engine. It was built by Richerd Longman. It had a Gordon Allen billet steel crank, with from memory a 51mm stroke running on plus 100 thou cooper s bore. Unfortunately the engine did not work well so I blueprinted the camshafts (649's) I got a perfect camshaft on the sixth one and even then had to havr the keyway remachined to ensure the cam was perfectly timed . I also had Chris Tyrell do the head for me from memory it was 11cc. I also fitted electronic ignition. To cut a long story short the car was written off on the first lap of the championships paddock at Brands. The light weight shell was absolutely amazing. I had the shell built on a chassis rig and the front bulkhead raised 100mm which in effect lowered the car 100mm lower than any other car, the floor pan was removed and replaced by a SHS platform chassis clad in 26 g aluminium The rear subframe was removed and replaced with a rose jointed beam axle. The car had a 54 ton steel roll cage in it with side intrusion bars. You could lift the back of the car up with the driver in the car. It was a stunning lightweight car and would no doubt have been unbeatable . Regards Mike"
http://tentenths.com/forum/showpost.php ... stcount=15
https://tentenths.com/forum/showthread. ... 215&page=2
- mab01uk
![Image](https://i.imgur.com/qa9tSw9h.jpg)
Castle Combe paddock circa 1980/81
Photo & press cutting: WOCCOWAYCER/Maguire Mini/Ron Carvell
https://tentenths.com/forum/showthread. ... 978&page=5
![Image](https://i.imgur.com/7JyGQ67.jpg)
I have a mini 7 that was owned , built and raced by Bob Sayer , i was told Bob used to work for special tunning at Longbridge. Car was a mk1 delux then wrote off in 1978, reshelled into a mk2 cooper s sprayed dark purple and wore number 31 1980 it was rolled at silverstone then underwent some factory love at Abingdon including jigging the shell was then painted blue and ran under number 49 then in 1981 a engine failure and that’s all I know , does anyone have any more info on this car as would love to know more
31 looks more like mini miglia spec. Guess there was no RAC stewards signature for that race.
- mab01uk
There is also a '1980's Mini Racing' thread on the TenTenths motorsport forum (link below) which may also be worth asking for info:-itsagoodalife wrote: ↑Mon Jan 25, 2021 8:33 am I have a mini 7 that was owned , built and raced by Bob Sayer , i was told Bob used to work for special tunning at Longbridge. Car was a mk1 delux then wrote off in 1978, reshelled into a mk2 cooper s sprayed dark purple and wore number 31 1980 it was rolled at silverstone then underwent some factory love at Abingdon including jigging the shell was then painted blue and ran under number 49 then in 1981 a engine failure and that’s all I know , does anyone have any more info on this car as would love to know more
https://tentenths.com/forum/showthread.php?t=142412
Also have you tried contacting the Mini Seven Racing Club for any info from their archives below, although I can't find the shop on their new website... ?
http://www.mini7.co.uk/
![Image](https://i.imgur.com/sm56ZRa.jpg)
![Image](https://i.imgur.com/8LFfxb2.jpg)
Yes sorry it was a miglia spec in number 31 !ivor badger 3 wrote: ↑Mon Jan 25, 2021 5:50 pm 31 looks more like mini miglia spec. Guess there was no RAC stewards signature for that race.
Thanks , car was restored and me and my father have purchased to hillclimb and sprint it , I have the last engine built by the late Rob Selby in it on a jack knight gearbox ... I will get some photos up once we have done a few bits to it
Harrison Kirby, The car I most regretted selling !!!!!!! Bob is now living in Wales and we have moved oop north
Get those photos up soon I know people here will appreciate your and your Fathers work, How is the Alfa coming along
Regards Graham Cooling
mab01uk wrote: ↑Wed Feb 03, 2021 7:51 pm
SMRC Ingliston Circuit July 1983:-
https://www.youtube.com/watch?v=IZOCvs--mJk
The chap climbing out the Bentley with in the racing overalls is iron man Andy Barton former min racer before he moved onto single seaters when this film was made.
Wonderful Andy sold me my replacement S engine. When not at university I spent quite a bit of time at Newburn garage.
Andy had a real ding dong for a couple of years in the 1000cc class with Cedric Bell Mini, Alex Clacher Imp and his mini. Given they were all three superb drivers the Imp at 1000cc was a real problem.
The story folk law goes Harry Ratcliffe turned up with a 1300? 8 port head and Andy badgered him for it . Head removed at end of meeting for £300 in cash!
Still the imps a problem one week AB car is on Webers next month on fuel injection.
Then Cedric turned up with a Cosworth MAE f3/2 engine. So next time I go to the garage Andy is full of it, on the floor is a Cosworth SCA F2 engine and he had found a works with one of those new fangled mig welders and proudly shows me an extended gearbox. Of course now Andy wins but perhaps too much power as he eventually rolls the mini flat Andy now walking slightly stooped
He explained it had that much power he could not tell how many wheels he was lifting at the chicane...Oh the roll cage if memory serves was made from inch box section.
After that it starts getting silly and the car Barton drove in the video is an AC3000 sitting on a March BDA F2 car
