casinogarage
Posts: 38 Joined: Sun Jun 27, 2010 12:13 pm
Post
by casinogarage » Thu Apr 16, 2020 12:45 am
This thermostat housing is new, freshly painted and after just some monthes stocking this oxidation appear !
Do you now a product able to stop this damage ?
bwaminispeed
Posts: 609 Joined: Sat Aug 21, 2010 4:05 am
Post
by bwaminispeed » Thu Apr 16, 2020 12:51 am
Probably wasn't cleaned well enough before painting..........
Best procedure is blast it, if possibly, a good coat of epoxy primer, and, then 2-3 good coats of paint to seal it against moisture intrusion...
Posts: 4854 Joined: Mon May 07, 2012 6:10 am
Has thanked: 189 times
Been thanked: 69 times
Post
by Spider » Thu Apr 16, 2020 1:27 am
As above, it needs blasting and then a proper etch-prime before painting, however, even then, don't expect miricles.
This is actually one item, being alloy, that Powercoats exceptionally well.
casinogarage
Post
by casinogarage » Thu Apr 16, 2020 12:14 pm
OK, many thanks, the lack of primer appear to be the explanation. I'll follow your advice ! I think use a new item will be better.
