Morris Cooper S bonnet badge position
coopertim
Location: In the garage spending far more time and money than my wife agreed to! Lincolnshire UK
Has thanked: 39 times
Been thanked: 13 times
Post by coopertim »
Morning all, I know this has been talked about before but does anyone have correct measurements for the holes in the bonnet to position the Mk1 Morris Cooper and S badges please?
Thanks Tim
Charlynsane
Re: Morris Cooper S bonnet badge position
Post by Charlynsane »
Here we go
Picture from the forum ;)
Hipwell
Post by Hipwell »
That not an Austin one??
Charlynsane
Oops Sorry my fault It's the wrong picture, I misread the thread
steve1071
Has thanked: 15 times
Been thanked: 16 times
Post by steve1071 »
gregor.tm
Post by gregor.tm »
I just measured my Morris badge on the bonnet and it is only 14,5mm from lower end of the bonnet.
It is original bonnet from never restored Mini.
Does any one have measurements where are S holes on the bonnet?
1964 MK1 Cooper
1965 Riley Elf
1966 Traveller Morris
1969 Spitfire MK3
1970 wifes std. mini
etc.
smithyrc30
Post by smithyrc30 »
Charlynsane wrote: Tue Mar 10, 2020 10:27 am Here we go
Those dimensions cannot be right.
The pins on the S are offset to the bonnet centre line, so they both cannot be 369mm from the LHS of the bonnet and 366 from the RHS.
I would say the upper measurements are transposed, RHS should be 369 and LHS 366
Gray
Post by Gray »
That is the pic of my original bonnet on my Austin 970s and the dims are as listed I can remember triple checking when I did the image about 7yrs back. Gray
smithyrc30
Gray wrote: Tue Apr 14, 2020 1:17 pm That is the pic of my original bonnet on my Austin 970s and the dims are as listed I can remember triple checking when I did the image about 7yrs back. Gray
Not questioning the accuracy of the numbers, just their relative positions on the diagram.
If the dimensions are as stated on the dimensioning lines, then the pins would be vertical. If the dimension line offset shown in the yellow ring is correct and there is not a 3mm offset to the sides of the bonnet, the dimensions in the black and blue rings cannot be correct because to cause an offset in the pin position at the centre the dimension to the edge has to change.
