Primary gear
Workinprogress
Primary gear
Post by Workinprogress »
Trying to clean up some crap will stuck at home and found this primary gear. Not sure what is it from due to extend nose. Guess automatic?
Thanks,
Bruce
Has thanked: 189 times
Been thanked: 70 times
Re: Primary gear
It's not Auto - they were different again.
That's from an early 850
bwaminispeed
Re: Primary gear
Post by bwaminispeed »
Yep, oil fed bush from early 850 and 997 Coopers.....
Workinprogress
Re: Primary gear
Ok, thanks. Will mark and throw back in box to be lost again.
Bruce
Re: Primary gear
Workinprogress wrote: Tue Mar 31, 2020 4:34 am Ok, thanks. Will mark and throw back in box to be lost again.
Bruce
:lol: :lol:
mnicoop63
Re: Primary gear
Post by mnicoop63 »
Early 850. I suppose if you were to change the rear bush in it you could use it on a 997. It is not correct for a 997 as is.
bwaminispeed
Re: Primary gear
Yeah, forgot, different tail shaft dia.....
I'll have to go check the NOS one I have.......
bwaminispeed
Re: Primary gear
Just checked mine, it's a 22A 520.....
Looks like the very first Deva bush style......It's for small tail shaft, and, I believe it was part of the conversion kit to modify early small tailshaft wet primary gear/crankshafts to dry.....
Workinprogress
Re: Primary gear
I did not see any numbers on mine.
bwaminispeed
Re: Primary gear
No numbers on these gears, mine was written on a piece of tape that was still readable....
Your gear is 22A 79, earliest gear for small tail wet primary gear cranks.......
The gear I have would be a Service Replacement with a couple of plugs (to plug the holes in the crank), as a "Fix" for the leaky wet style gears that leaked oil all over the clutch......
