R/H tank straps
R/H tank straps
Do the straps that secure the right hand petrol tank have a cushion or anti-chafe tape between the strap and the tank?
- Has thanked: 18 times
- Been thanked: 51 times
Re: R/H tank straps
Am I wrong in thinking that they are the same part for either side?
Makes sense to have the tape
Re: R/H tank straps
cut 1" strips of 2mm cork gasket paper and glue them on the contact side only.
https://www.amazon.co.uk/dp/B07WLLL4RY/ ... TE_3p_dp_1
- Been thanked: 10 times
Re: R/H tank straps
Any tank strap should always have something between it & the tank. Never a good idea to wear holes in your petrol tank.
Re: R/H tank straps
Thanks for the replies. I seem to remember on my first car that the straps had a sort of heavy duty paper on the contact side of the strap but I like the idea of 2mm cork paper. Will give it a try.
- Has thanked: 38 times
- Been thanked: 52 times
Re: R/H tank straps
When i stripped out my car the tanks had ex Leyland Parts Box Cardboard cut into the long strips to tighten up between the Tank & its Strap? easy to id as some of the Leyland still showed & that Blue card seen on one side.. proof that Leyland cardboard packing lasts some 20 odd years & 40k miles later .. when i took both Tanks out the Straps & Tanks were still perfect .. no i did not re-use this packing but somehow now i wish i had.
Re: R/H tank straps
Used a 2mm cork paper with adhesive on one side. Worked well, thick enough to protect but thin enough to be flexible and not crack. Thanks for the suggestion.croc7 wrote:Thanks for the replies. I seem to remember on my first car that the straps had a sort of heavy duty paper on the contact side of the strap but I like the idea of 2mm cork paper. Will give it a try.
Re: R/H tank straps
Strips of thickish card smeared on both sides with Tiger seal or the like, and allowed to cure works well.
