my replacement Heritage Bonnet is now on my Austin1070S ..i now need to drill the Holes to mount the Austin Cooper Badge & the small "S".. i am not too sure that my original bonnet was OE as both the Bonnet Badges their location seemed to me out of align ?
Question.. where do i need to position the badge Mounting Holes in my new Bonnet for the Austin Cooper Badge which has 2off 1/4 inch dia; securing Pins also the small S needs the two holes for the mouse condoms .. Q is there a dimension / location drawing for these Austin Cooper badge holes?
Many Thanks,
Austin Cooper Badge Holes location in Bonnet Q
- Has thanked: 38 times
- Been thanked: 52 times
- mk1coopers
Re: Austin Cooper Badge Holes location in Bonnet Q
The search button is all knowing
, it also depends on if you are using repro or original badges, double check against what you have in your had to fit
viewtopic.php?f=5&t=5834&start=0
