Rear quarter piano window dismantle
AndyB72
Post by AndyB72 »
Any tips on how to separate the frame from the glass so I can either swop the frames over or send them for chroming. Do I just go in with force or is there something to soften the rubber first?
roymck
Re: Rear quarter piano window dismantle
Post by roymck »
Use a hot air gun to heat up the rubber and soften it
8662 FN Austin Mini
Yes I know it’s not original
My wife says I don’t listen to her or something like that !
dodge44
Post by dodge44 »
I found that the frames just slipped apart after soaking the rubber in White spirit. The seal will undoubtedly need replacing anyway - fitting the new rubber can however be a right faff so be prepared...
