Cleaning the main bearing oil feed nearest to oil pump as far as i can see it gets it supply from one of the two main gallerys , as the other main bearings.
Question i am assuming i is should i be able to get brush from main bearing all the way until it shows in oil gallery, is this right ?
Have also tried strimmer nylon without luck -paraffin does get through though.
The main oil galleries have been tapped by machine shop for threaded plugs - my concern, maybe unfounded, that this might of blocked oil way.....
Appreciate some opinions......
