drum to disc conversion, wheel spacers
- dhenry
Hello,
This weekend I upgraded my 66 Morris to Cooper S brakes. Everything went as it should and I am very pleased thus far. The fit and quality of components is great however I am left with 2 problems which may be common knowledge to most. First, do I need a brake master cylinder as I do not think my standard one pushes a great enough volume of fluid. If the answer is yes, which i have a feeling it will be do i have to have the large capacity cooper brake master with the metal reservoir or can I use the cheaper standard brake master with the plastic reservoir?
Second, the track is now wider at the front. I have read that the cooper had wider drums on the rear that had a built in spacer. I may choose to put cooper drums on at a later date but in the meantime how much spacer might i need to match the front track? Thanks again for the help.
Daniel
Daniel
Re: drum to disc conversion
dan
the bore size of the master is the same, the s master is just taller so that it doesnt run out of fluid when the pads are well worn down - if you use a std master you just need to be mindful of the fluid level.
a set of 3/8th spacers will do the job of you want on the rear
- dhenry
Hmmm, so you say they are the same. Here is my problem. My brake pedal travels to the floor and still wont lock the front brakes. I have bled the system through completely at least 3 times left and right and i still can't get it to work. Am I missing something? I have not bled the rear though, do i need to bleed them also. I was going to try bleeding the rears but it was getting dark last night. There are no leaks either. Any thoughts?
where are the bleed nipples on the front calipers?
bottom or top?
should be at the top
bottom or top?
- dhenry
I just read this on another forum. I think they may be at the bottom which means i need to swap my calipers over. That should be easy. Hopefully this will solve my problem then.
loads of people make this mistake!
id bleed the rears whilst you have it up in the air - at least then its all new fluid and you know its right
- dhenry
school boy error. thanks for being kind. I will update my thread in the "our cars" section as I have been getting a lot of work done lately. Cheers,
Daniel
Daniel
- dhenry
Re: drum to disc conversion, wheel spacers
And in regards to wheel spacers. Any other thoughts or will 3/8" be adequate. I just read that the cooper drums have a whole inch in them. Thanks,
Daniel
Daniel
dan
the rear spaced drums are roughly 3/4 - 1" wide, but if your going this wide you will be restricted to a 4.5" wide wheel (unless you have arches)
if you use 3/8 they will take a 5" wheel with no problems
it all depends on your wheels / arches
- dhenry
I see, my wheels are quite wide. The tires I am running are 165's. I think the wheels are either 4.5 of 5 i am not sure. I will have to check. I may have to run some arches.
