Andrew1967
Post by Andrew1967 »
swindrum wrote:I would be interested in the tunnel section that has the hump for the push button, I have a car that looks like they pulled out the engine through the shifter hole....
Yeah, be nice (well, amazing really) for something from this shell to be re-used :lol:
Will get a couple of pics of it.
rich@minispares.com
Post by rich@minispares.com »
Andrew
I'm confused, I thought you where going to use the floor and replace the rest?
:lol: :lol: :lol: :lol: :lol:
'long beard boss'
Andrew1967
rich@minispares.com wrote:Andrew
:lol: :lol: : :lol: :lol:
:lol: :lol: :lol:
Parts of the floor are better than the rest of the car so I can understand your confusion Rich
java gt
Post by java gt »
I am so glad you are taking on a job of this magnitude,it will serve as a how to for when I start mine.On the subject of bracing a friend of mine had a very rusty Elf and he made 3 upturned U shapes with 6" box section and suspended the Elf shell on them and clamped the drip rails onto the U frames and fitted very thing from underneath.It worked for him as the shell was straight to start with but I suspect I will have to come up with another plan as I think there was movement in the A post of mine which is pretty much none existent.
swindrum
Post by swindrum »
Thanks!
Gray
Post by Gray »
Those plates on my tunnel were loose and not welded Andrew.
Hipwell
Post by Hipwell »
No going back now Andrew! ;)
My seat brackets are the same.
Andrew1967
Thanks Gray - will have to post up a question to see when they were changed.
Matt - Yes, no turning back now - got it fairly well planned out how to go about it .
Andrew1967
Got the remains of the floor and heel board off yesterday, ready for the temporary attachment of the new floor assembly when it arrives.
Leaving the seat pan and pockets in for the time being as they will be good reference and temporary mounting points for the floor. Same as the toeboard.
Wood support under seat pan to allow me to drill out spot welds without bending it :roll: :lol:
swindrum
Post by swindrum »
Great progress!
gogsymac
Post by gogsymac »
Andrew - are you going to keep the toeboard ? It doesn't look too bad from the photo.
Andrew1967
Hi Gordon,
No, that's being replaced as well as it has gone in the upper corners. :(
There's not going to be a huge amount left of the original shell :shock:
gogsymac
Post by gogsymac »
Andrew - that makes sense. I had the same problem with my 1965 rustbucket. I bought a new toeboard from M Machine (modified to Mk1 spec) and it took a bit of time to tease (ie bash) it into place. It was worth it as it provided a good guide to fit the whole new floor which was also bought from M Machine.
One thing which I found was that it is essential to keep the front of the car well supported across the whole of the front subframe - not just at the front of it under the front panel as that would cause the body to flex a bit. I stuck a plank of wood right across the middle of the subframe and supported it well and that did the trick. It was easy just to lower the top part of the shell onto the new floor.
Andrew1967
This arrived yesterday 8-)
harrymini
Post by harrymini »
Looking good, sent you a PM
111Robin
Been thanked: 17 times
Post by 111Robin »
Better than Christmas Andrew.
docka
Post by docka »
Flat pack self-assembly? :lol:
mk1coopers
Post by mk1coopers »
Would it be worth lead loading the joins between the floors and remote tunnel to give more of a factory look, possibly before it goes in the car ?
rich@minispares.com
mk1coopers wrote:Would it be worth lead loading the joins between the floors and remote tunnel to give more of a factory look, possibly before it goes in the car ?
or pour bitumin in and glue the carpets on top for that 'authentic' early 1980's restoration..... :lol:
'long beard boss'
Andrew1967
:lol: Note to oneself - Don't buy an older restoration of Rich :shock: :lol:
I do want to lose the joins. Lead loading would probably be less likely to crack than filler ? Another first for me maybe !
Bitumen is flexible though :lol:
