Cracked S block
andy1071
Cracked S block
Post by andy1071 »
I have been looking at a few 1071 S blocks, and it seems quite common that they crack horizontally along the block, between the tappet chest and cylinders.
Has anyone else come across this? Or am I just lucky :roll:
-It did seem that they were cracked in-line with the end of the machining from the cam follower bores. -Makes me think that I will carefully blend out these areas when I come to build my engine.
/Andrew
dutchacme
Re: Cracked S block
Post by dutchacme »
I know of a 1293 race engine for a german historic racer which cracked during a dyno session in the same way. The crack was not noticed, once in the car the mechanic expereinced a mysterious water loss. A devil to find.
wim
970 racer
Toby
Has thanked: 12 times
Re: Cracked S block
Post by Toby »
Any pics of the cracks Andy? Will have to check my block as well then
T.
andy1071
Re: Cracked S block
Post by andy1071 »
Sorry no pictures, I'm afraid.
The worst one was cracked from side to side (cylinder 1 to cylinder 4) more or less in the middle of the tappet chest. -It was very obvious :shock:
I have also seen cracks around the threaded boss for the tappet cover bolt (as though somebody had over tightened the cover bolt -it must of been REALLY tight!)
251 ENG
Re: Cracked S block
Post by 251 ENG »
May be something to do with your cold weather
andy1071
Re: Cracked S block
Post by andy1071 »
It's lovely weather over here in sunny Sweden (well, today anyway....)
