Fitting special 2 core rad
cookie1071
Post by cookie1071 »
Any tips for doing this without stuffing up the fluting on the rad? It's going into a MK1 with conventional plastic fan but last time round i managed to make a right mess of the rad :oops: - is there a particular sequence i should follow? :? Any tips much appreciated. ;) Cheers, Niall.
mk1rally
Re: Fitting special 2 core rad
Post by mk1rally »
might sound daft, but tape a piece of cardboard to the rad face that can be removed when its in place. It helps a bit.
My pork pie hands dont help on this job!!
I also modifed the bottom shroud so that I can fit it first and then put the rad in place. Not ideal if it's a show queen though.
cookie1071
OK tks Dave, i'll do that - do you normally fit the fan first and then try and shove the rad down past it or do it the other way round? :? :? I tried both and the first method looked like it was goind to end in a badly crushed rad and with the second i just couldnt get the fan between the fitted rad and the 'nose' of the water pump - arrrgh!! :evil:
N.
PS. Will suss out those bits this wend and report back. ;)
cookie1071
cookie1071 wrote:do you normally fit the fan first and then try and shove the rad down past it or do it the other way round? :? :? I tried both and the first method looked like it was goind to end in a badly crushed rad and with the second i just couldnt get the fan between the fitted rad and the 'nose' of the water pump - arrrgh!! :evil:
anyone? :?
sclemow
Post by sclemow »
I ended up doing both - it was really fiddly though. I put the bottom bracket in, fitted the rad to it, then put the fan on, then put the top half of the shroud on.
