mk1 door
- Nick W
mk1 door
these doors where nos, they where the same as the original doors I have except I didnt notice these holes untill now!
thought at first maybe mk2 doors had it for access for the boss, but its not lined up with that.
thought authi had wind up windows?
Up North in Sheffield
- rich@minispares.com
Re: mk1 door
all later mk1 doors had them from the early 1960s (cannot remember the change point, but it is a known)
- Has thanked: 150 times
- Been thanked: 137 times
- Costafortune
- Has thanked: 36 times
- Been thanked: 38 times
- Been thanked: 13 times
- Nick W
Re: mk1 door
well this wasn't the look I envisaged...but then again
the holes will be going!
- billycooper
Re: mk1 door
Nick W wrote:well this wasn't the look I envisaged...but then again![]()
well there you go, learn something new everyday, let me check KEC, that's a good deterrent !
i never knew what the hole was for, but from my memory as an ex Rover / Austin parts boy, these were van doors, and the MK1 doors were superseded to this part number in the 70s, i think it was the only difference
Steve "Murph"
Re: mk1 door
I always thought that the hole appeared when the safety boss did so that you could poke the screwdriver though and fit the screw to the boss?
padlock hole though.....
- smithyrc30
Re: mk1 door
Not if any of th cars I have owned are anything to go by.rich@minispares.com wrote:I always thought that the hole appeared when the safety boss did so that you could poke the screwdriver though and fit the screw to the boss?
First one was a 67 Austin SDL, no holes, second a Morris Mk2 68, no holes.... etc.
The current 2 one late 69 Austin Mk2 and one 70 Morris Mk2 no holes and all are/were still on their original doors.
I always thought the hole was on van doors only. At least that was the way it appeared when wandering the scrap heaps of the early 80's
Re: mk1 door
Just had a look at mine and it does have those slot things. BUT my doors were new doors from Leyland/Unipart in 1983/4 ish when I got them via my neighbour who worked there for cost plus 10%. I noticed the slot them. It doesn't even remotely align with the safety button thinggy. The bad/sad bit about the Unipart scheme was that the employee had to own the car before he could take advantage of the scheme. So a quick paper sale was arranged and I greedily took full advantage of it. Happy days here in Oxford
- minimans
Re: mk1 door
That would explain it if the number superseded to the van door for all cars, it would be because the van lasted the longest with external hinges and would have been the last manufactured door for stock purposes?billycooper wrote:Nick W wrote:well this wasn't the look I envisaged...but then again![]()
- Pete
- Has thanked: 59 times
- Been thanked: 149 times
Re: mk1 door
Can't see it cos the boss is further over than the hole. I did hear it was for an extra lock on the late vans, but then you'd only be able to fit one unless you exited the van via the back door?!rich@minispares.com wrote:I always thought that the hole appeared when the safety boss did so that you could poke the screwdriver though and fit the screw to the boss?
- Has thanked: 4 times
- Been thanked: 23 times
Re: mk1 door
When breaking into Australian Minis with the wind-up windows the idea was to go in through the passenger side. It doesn't take long to press in the triangular quarter vent window, push a key or something in through the seal and flip its latch up, swivel open the window, then reach in and un-snib the lock. On the driver's side the door is locked with a key from the outside, so its moderately more difficult.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
1955 BSA C11G
1969 Triumph TR6R
