appropriate steel bar choice
- Pandora
I'm going to buy some 1/2" steel bar to make the top pivot pin for the 7's front suspension
it's part 22 on this exploded diagram.
http://www.lotus-europa.com/manuals/s2parts/c/index.htm
the top wishbone pivots on it, as well as locating the top of the coil over shock.
any thoughts on whether I need a specific grade of steel, or will 'standard' steel bar suffice?
- Ronnie
- Been thanked: 7 times
Re: appropriate steel bar choice
I would think as a minimum use EN8, but be aware a lot of suspension components as supplied as OE may possibly have had heat treatment, when you purchase the material will be in its annealed state.
- Pandora
Here's a handy link - http://www.roymech.co.uk/Useful_Tables/ ... gth_st.htm
I recon I'll need EN32, 16 or 19?
will these be hard to turn/thread?
I would certainly not consider using anything less than EN16 for that. It looks pretty stressed to me.
In my usual belt ans braces fashion I would suggest using something that is as good as possible, even if it means paying someone to turn it for you. A few quid spent now is far preferable to seeing your front suspension collapse from under you at high speed!
- Pandora
Indeed! hence my question. better than asking 'Why did my suspension callapse?'
My lathe is a bit asthmatic, so might need to farm it out as I don't think it'd cope with anything harder than edam cheese.....
It's only a couple of bars 210mm long with a 20mm long 7/16th UNF thread on each end. Can't be all that pricey to get done.
- Pandora
- COOPERCO
Another vote for EN24T, just don't weld it!!
In the garage with tourettes!
- Pandora
- Ronnie
Dont forget the rest of your suspension bolts will only be HT s quality bolts.
what are the dimensions?Pandora wrote:anyone able to make these for me?
if its within an aston db4 head stud (1/2" by 8" aprox of good qulity material,with 1" of 1/2" UNF thread one end and 1 1/2" of UNC at the other end) i could turn you a pair up. got plenty of old 6 cyl head studs about.
as has been said, en8 + will be fiiiiine , can you not buy them off the shelf?
- Pandora
I'd been thinking they need to be 210mm long with about a 20mm long 7/16th UNF thread on each end. but if you can make something suitable out of studs you have, 1/2" UNF threads will be fine - it's a special, so I am making the wishbones etc myself anyway, so can adapt things a bit.
I can't seem to find a supplier of S4 spares, and the europa folk I tried didn't have any
in fact, it sounds like the studs you have might not even need machined- they might be perfect as they are!
