Fuel pump wire.
ChrisM
Fuel pump wire.
Post by ChrisM »
Sorry.... Just a quick one.
67 negative earth car - White wire to the 12v terminal on the back of the pump, black wires to the screw on the body? It's a new neg earth SU pump from Burlen with the electronic guts.
Cheers - Chris.
dklawson
Re: Fuel pump wire.
Post by dklawson »
Yes, the wiring you describe is correct for a negative earth car with a negative earth pump.
Doug L.
ChrisM
Re: Fuel pump wire.
Post by ChrisM »
Thank you Doug.
rogerotto66s
Re: Fuel pump wire.
Post by rogerotto66s »
I was about to wire my fuel pump on my positive earth 1966 Cooper S.
Here is how I was going to do it based upon the wiring diagram.
This is the same wiring suggested for the negative earth car.
Please confirm.
Roger Williams
Ronnie
Has thanked: 12 times
Been thanked: 31 times
Re: Fuel pump wire.
Post by Ronnie »
If you check your wiring diagram you will find the white wire is a switched ignition feed (unfused), if you check with a meter & your battery is connected + positive to ground that feed will be - negative. The colour is the same British Standard used positive or negative earth the colour of the wires does not change, if the fuel pump is electronic make sure you have it correct, if it is points it will make no difference. ;)
rogerotto66s
Re: Fuel pump wire.
Thanks Ronnie.
I rebuilt the original pump so it is using points.
So.. I am OK as pictured.
Roger Williams
Ronnie
Re: Fuel pump wire.
Post by Ronnie »
rogerotto66s wrote: Sun Aug 01, 2021 1:57 pm So.. I am OK as pictured.
It looks good to me. ;)
