Tachometer for Mk1
mk1coopers
Re: Tachometer for Mk1
Post by mk1coopers »
Here's the 7000 rpm smiths one I have, I don't really need it so if someone wants to make use of it I can put it in the for sale section, it's untested.
GraemeC
Been thanked: 7 times
Post by GraemeC »
I like that, is it 80mm and I wonder if it will work on -ve earth?
Been thanked: 10 times
Its ridiculously simple to swap polarity on the car if needs be.
GraemeC
Post by GraemeC »
Thanks Mark,. Yes swapping the car isn't difficult, but I'd rather keep it the more commonly understood -ve Earth than change it just suit a tacho.
Good call ;)
GraemeC
Post by GraemeC »
Just need to find a sensibly priced 80mm one that doesn't bounce around like its on acid.
Don't want to spend much as I only use it for noise test in scrote-ineering
You can exclude all the "classic" second hand ones then.
Something like this is a good bet.
https://www.merlinmotorsport.co.uk/p/ra ... eter-rttc8
GraemeC
Post by GraemeC »
That would work, f I can find one at reasonable cost.
eBay.......
mk1coopers
GraemeC wrote:I like that, is it 80mm and I wonder if it will work on -ve earth?
Yes 80mm, I picked it up ages ago as I'd not seen one like it before
