1380 block
Daves 8 port
1380 block
Post by Daves 8 port »
Anyone know if it's feasible to liner a 1380 pot and rebore it back to 1380 ??
minimans
Re: 1380 block
Post by minimans »
Tried to do that back in the 70's and it didn't work the walls are too thin on the liner, but maybe with new technology and prayer it's possible...........
LuisM
Re: 1380 block
Post by LuisM »
I've seen a block sleeved for 75mm :shock: Pistons, so it should be doable for 73,5. I recall they bored one cylinder then fit sleeve..then move to next one, instead of boring all cylinders and fit sleeves after. Cheers, Luis
Daves 8 port
Re: 1380 block
Thanks lads, looks promising then. What pistons were they Luis ?
LuisM
Re: 1380 block
Post by LuisM »
they were honda pistons, not sure about model, used with 91mm long stroke crank for +1600cc.
These exotic builds were common here on the Slalom/Autotest racers.
Luis
Daves 8 port
Re: 1380 block
That's very interesting. Not heard of that one. is it reliable for consistent and long use though ?
LuisM
Re: 1380 block
Post by LuisM »
not sure if this is a build spec for a road car... seen a few failing in action.
Daves 8 port
Re: 1380 block
That's what i was thinking. About 1450 is max for reliable road use i believe.
Been thanked: 10 times
Re: 1380 block
I would say WAY to big for reliability.
Daves 8 port
Re: 1380 block
Agreed !
