Hello guys,
I have to retrim my lower dash rail
does anyone have a pattern of this?
http://www.minisport.com/mcr41-vinyl-co ... black.html
I already have the material, but it's the first time I will do this!
Thank you guys!
Lower dash rail skay patern
- Location: Cumbria, The lakes, were the roads are always quiet, and the sky is nearly always blue
Re: Lower dash rail skay patern
I recently covered the top and bottom dash rails of my Elf, using the vinyl from Newton Commercial.
Similar to Minisports but I had to cut the templates first.
The method I used was to buy a big bag of pegs from Wilkos , I clipped the vinyl to the dash first to see how it would lie and used a hoppy knife to cut the holes for the vents/switch panel first.
I then used Evo Stick and applied to the dash rail only I then positioned and clipped with the pegs the vinyl as I worked from the drivers side to passengers I used a sponge to flatten down/position.
This was my first attempt
Thank you for your help
I will try to use the same way to wrap my lower dash,
The most difficult will be to bend the vynil on the round corner..
- minimans
Use some heat to warm the material the wifes hair dryer for instance...............Charlynsane wrote:Thank you for your help
My wife will kill me lol
But I will of course warm it! lool
An d I use a neoprene spray, very efficient
