1965 Riley Elf Painted and on her Wheels
100BUR
Location: Cumbria, The lakes, were the roads are always quiet, and the sky is nearly always blue
Post by 100BUR »
This is my 1965 Riley Elf "Rita" purchased in early 2014 via ebay
The pictures on ebay defiantly shown her good side and once home there was a lot more body repairs than original we thought.
As the rebuild of the body work started, the mind-set became fit new it will last longer !!
New floor has gone in along with complete front end including inner wings, and a new rear valance
Colour is Fiat 500 Tec House Grey, with Pepper White Roof from the new Mini
1275 MG Metro engine is being rebuilt with stage 3 head and a MED road cam
acespeed72
Re: 1965 Riley Elf Painted and on her Wheels
Post by acespeed72 »
Looking Ace....
100BUR
Post by 100BUR »
Thanks it's been a long time coming
Few more pics
Craig
Post by Craig »
Love the dash and the seats !!! :D
Did you refinish the dash yourself ??
Craig
100BUR
Post by 100BUR »
No
The dash was refinished by Chapman & Cliff
Van13
Post by Van13 »
That is going to be smart when built up,nice choice of colour
Very smart indeed!
69k1100
Post by 69k1100 »
Anyone buying these cars in the future will think BMC were a well run, high standard organisation!
100BUR
Post by 100BUR »
Thanks for all the great comments much appreciated
The rebuild is not going quiet to plan....
Couple of teething problems with the engine rebuild which hopefully are now sorted
The radiator would not line up on the thermostat bracket. A 1275 GT top rad bracket has solved that one
We had to take the flywheel off again and re-lap to pull everything up and worked out that the clutch would now work.
We have an issue at the moment with the sidelight grills will not line up with body/pull in flush with the body, initially we thought that a slight touch on the grill (We tried an old one first) with the grinder would pull in it has not.
We are taking Easter off to enjoy the chocolate
My thinking now is that the cut outs in the front panel (M Machine) are slightly out of line
100BUR
Post by 100BUR »
Update on Elf Progress
The engine is now in, and I have covered the top dash rail.
Both jobs were quiet painless, I am really pleased that the dash rail went well
Still have a couple of issues
The wiring harness does not seem long enough to reach the starter, it is a new Mk3 mini harness
Neither the 1275 GT rad bracket or the shinny S bracket seem to line the radiator up square
rich@minispares.com
Post by rich@minispares.com »
is it my eyes, or have you put the fan on back to front????
p.s the clingfilm over the wings is a great budget idea to prevent oily scratches when working on the engine!
'long beard boss'
Matt_Tupman
Post by Matt_Tupman »
I like the contrast between new and old styling nice job.
100BUR
Post by 100BUR »
Thanks Rich yes the fan is on the wrong way :oops:
Does anyone have a pic of the route of the wiring harness from fuse box to starter, at the moment it does appear a little short to us.
Really appreciate all the help and advice from all the forum members :D
InimiaD
Post by InimiaD »
What starter are you using.? I can't quite tell from your pic.
If it's a pre engaged type the solenoid is on top of the starter as opposed to a seperate solenoid that could be fixed to the inner wing.
100BUR
Post by 100BUR »
Pre engaged starter. we have fitted new Mk3 Mini wiring harness
Andrew1967
Post by Andrew1967 »
I'd have thought the solenoid wires on a Mk3 loom will be much shorter than required for a pre-engaged starter.
As per previous post, the solenoid on a Mk3 Mini is usually placed on the inner wing, low down.
100BUR
Post by 100BUR »
Thanks looks like I will have to add some length to the wiring harness
I will have to dig my soldering iron out first job tomorrow is a visit to the electrical store :)
rich@minispares.com
if you are using a loom for an inertia but using a pre engaged starter it easy to sort
leave the old solenoid on the wing, but just connect the starter wire to the same terminal as the main battery lead, use the old thick cable to go down to the starter, then just extend the single white/red solenoid wire down to the pre-engaed starter.
job done, no messing with the thicker wires and it all looks nice and neat
and it saves having to put ring terminals on all the brown wires and the struggle of getting them all onto the single terminal on the pre-engaged starter
'long beard boss'
100BUR
Post by 100BUR »
Thanks Rich
looks like another Minispares order ;) :lol:
Sounds a lot better idea
JC T ONE
Post by JC T ONE »
Nice project 8-)
