Moved to the back of the car, mostly for a change of view. I decided to hang the rear doors and square up the opening before welding the bottoms of the door frames to the lower door step. Look at me, thinking ahead!
Well, it turns out I didn't think far enough ahead... When I had tacked in the new door step panel, I had used the side load space finishers as mu guides for the rear step. got everything nice and square and tacked it all together. Fast forward to Saturday when the doors were hung and there was about 3/8" gap along the bottom right edge. No problem, adjust the hinges a bit, oop, now the gap it top left...
Now, I had known the car had been bumped in the back at some point in its life, but what I hadn't realized, was that the bump transferred from the rear corner of the car, through the right side loadspace cover, to the back seat crossmember, pushing said crossmember forward, by, you guessed it, 3/8 of an inch...
So, Sunday was spent carefully taking out the nice new M-Machine rear step panel and massaging the crossmember back to where it belongs and fitting the doors, again...
