Gearbox casting number
ivor badger 2
Post by ivor badger 2 »
I have a friend with a 22G382 gearbox casing. What is it from and what is the correct casing for a 1071 S?
rich@minispares.com
Re: Gearbox casting number
Post by rich@minispares.com »
its a 3 sync b type box magic wand used in elf / hornet
'long beard boss'
mk1coopers
Post by mk1coopers »
I think (waits to be corrected :lol: ) that some early cars had 22G68's and the later (most) cars had 22G190's, there may have even been a bleed off into the 333 casings right at the end of the run
Toby
Has thanked: 12 times
Post by Toby »
Maybe it's good to read through this thread on the subject of 1071 casing numbers:
viewtopic.php?f=5&t=10990
Number Six
Post by Number Six »
rich@minispares.com wrote:its a 3 sync b type box magic wand used in elf / hornet
Its also used in the English Mini Moke...
André
Moke My Day
Supersonic
Post by Supersonic »
What I have found over the years is that there are three types of the 22G382 3-synchro B-type gearbox all with the 22G231 laygear. Where I have seen this box original from the following vehicles:- magic wand box were from the Elf & Hornet, Mini remote diff housing box also from the Elf & Hornet and with the 1100 type diff casting in the MG, Riley, Vanden Plas and Wolseley 1098cc ADO16 cars.
Most tended to have a 3.76 final drive and were rubber joint type.
Hope this helps someone.
Alan
nick rogers
Post by nick rogers »
I'm surprised you found 3.765 diffs in ADO16 1100 3 syn boxes. I only ever found 4.1's.
Supersonic
nick rogers wrote:I'm surprised you found 3.765 diffs in ADO16 1100 3 syn boxes. I only ever found 4.1's.
Nick, the twin carburettor 1098cc ADO16s mostly seem to be 3.765 final drive and the single carburettor 1098cc units mostly tend to be 4.1 final drive.
But again I have a very early Wolseley 1098cc car and it has a 4.1 final drive believed to be original to the car so God knows?
Alan
ivor badger 2
Alan
Being a Wolseley, it probably came with a single carb engine.
