HS4 Airbox
- minidean
HS4 Airbox
If I put HS4 Carbs on my mk3 coopers, does anyone know what mods would need to be made to the manifold and airbox? What would the period be?
UPR 65 1963 MK1 Super Deluxe
FTX 217K 1971 MK3 Cooper S
- Has thanked: 208 times
- Been thanked: 80 times
Re: HS4 Airbox
The Manifold would have been a 12G1263. These are identifiable by the flange that the carbs bolted up to, they are square-ish in shape and could take either HS2's, HS4's or be drilled for HS6's. This is also the Manifold that was factory fitted to the Aust Clubman GTs built to SPO 28 as Highway Patrol Cars for the Police.
The particular Air Filters used on these were locally manufactured here in Aust and as far as being Air Filters go they were rubbish.
I have to say, I've not seen an Airbox Style Air Filters fitted with Twin HS4s on a Mini, though it may have been done, but I've not come across anything from the factory that way. They seemed to use separate Paper style air filters.
- timmy201
- Been thanked: 42 times
- minidean
Re: HS4 Airbox
So what sort of air filter would normally be fitted to twin hs4's???
- Ronnie
- Has thanked: 13 times
- Been thanked: 35 times
Re: HS4 Airbox
I believe that Mark F (Mk1) converted an air box for bigger carbs (neat job) it may be on the old forum
- minidean
Re: HS4 Airbox
Thanks Ronnie, I have seen these and they do look good,
Re: HS4 Airbox
here is my solution to air filters on a pair of HS4s.....
