Im atempting to build up my remote change 4syncro CR gearbox but encountering an issue. All cr parts were good 2nd hand purchased individually.
Ive utilised the orginal gears and mainshaft from the box and added the cr laygear 22g1040 and a 18 tooth 1st motion shaft.
On fitting the laygear the box becomes very hard to turn over. The laygear is stamped 22g1040 so i know this is correct. Im suspicous of the 1st motion shaft primarily as if i replace it with a 17 tooth version the tightness goes away( im aware the mesh is incorrect for the laygear but trying to isolate whats causing the tightness).
The 1st motion shaft has 18 teeth and takes the 14mm bearing and has a 'S' stamped in it.
? Could this have the later A+ gear angles on it despite having the 14mm bearing ?
Any thoughts appreciated.
