Innocenti wiring diagram with key/description?
- sandman
Anyone got or know where i can find wiring diagram for Innocenti Cooper, that also include the key or description to the diagram?
Ive found a diagram on Google, but thats no real help without knowing whats what on the diagram.
Anyone that can help?
Cheers,
Ed_
Ed_
Re: Innocenti wiring diagram with key/description?
I have an Inno 1300 Export diagram from the owners handbook which I have translated.
WIRING DIAGRAM KEY
Components
1 Headlamp
2 Side Lights/Turn Signal
3 Side Repeaters
4 Horns
5 Distributor
6 Coil HV
7 Alternator
8 Water Temperature Sender
9 Starter Motor
10 Reversing Light Switch
11 Stop Light switch
12 handbrake light Switch
13 Horn Relay
14 Starter Relay
15 Two-speed wiper motor
16 Dual circuit brake switch
17 Temperature Gauge
18 Ammeter
19 Oil pressure gauge
20 Tachometer - warning lights side and headlights
21 Speedometer – warning lights generator and direction indicators
22 Fuel gauge with reserve warning light
23 Electric washer motor
24 Dimmer switch
25 Flasher Unit
26 Fuse Box
27 Ignition switch and starter
28 Switch exterior lights
29 Wiper switch
30 Switch electric washer
31 Hazard Light switch
32 Heated rear window switch
33 Electric fan switch
34 Electric fan motor
35 Cigarette Lighter
36 Dual circuit brake warning light
37 Door switch left.
38 Ceiling
39 Door switch right.
40 Fuel level sender and reserve light switch
41 Electric fuel power
42 Battery
43 Tail lights, brake lights and reversing lights
44 Number plate light
45 Heated rear window
46 Indicator switch
Cable colour-codes
A Blue
B White
C Orange
G Yellow
H Grey
M Brown
N Black
R Red
V Green
Z Purple
WIRING DIAGRAM KEY
Components
1 Headlamp
3 Side Repeaters
4 Horns
5 Distributor
6 Coil HV
7 Alternator
9 Starter Motor
13 Horn Relay
14 Starter Relay
18 Ammeter
24 Dimmer switch
25 Flasher Unit
26 Fuse Box
29 Wiper switch
38 Ceiling
42 Battery
46 Indicator switch
Cable colour-codes
A Blue
B White
C Orange
G Yellow
H Grey
M Brown
N Black
R Red
V Green
Z Purple
This is a colour version of the Inno i made years ago, the parts on it are the once on the list above. But as the layout of the schematic is very near the layout of the car you can't really miss.
Cheers,
Jack
Cheers,
Jack
- sandman
Many thanks guys - this will be of great help!
I noticed that on the back of the tacho there are more connectors than shown on the w.diagram.
Any of you got a photo or could list which connectors to use?
I really don't want to "fry" the gauge!
Cheers,
Ed_
Ed_
- sandman
surfblue63,
Are you sure the diagram you've posted is exactly like the one in your owners manual?
The keys you've posted indicate that switch no. 31 is for the hazard lights, but the one one the diagram show that 31 is for the gauge illumination....
I'm having some probls with tha hazard lights so would be thankful if anyone could help out and tell me how they should be wired..?
Cheers,
Ed_
Ed_
Yes my translation is incorrect, 31 is the switch for the gauge illumination.
My Inno Export does not have hazard lamps, and I am pretty sure that none had them fitted as standard. Where is the switch on your car and do you have a picture of it?
- sandman
The switch is mounted on the heater facia, just under the cigarette lighter.
I'm 99% it's a factory fitted item as it's looks very similar to the heated rear window switch. Theres even an italian type hazard relay fitted on the side of the pedalbox - this has 4 or 5 connectors. Problem is I can only get one side to work.... ?
Cheers,
Ed_
Ed_
I have had another look for information and found that the German market Innos had hazard flashers. They were fitted with a rocker switch, with the standard triangle symbol, under the cigarette lighter.
- sandman
Many a Mini has been imported from Germany to Norway, so that makes perfect sense.
Btw, problem sorted now.
Cheers,
Ed_
Ed_
