Hi
Hope someone can help got a rod change box with LSD and hardy spicer out puts will rubber coupling output shafts go on or are the splines different or is it possabel to get the hardy spicer parts to go on early driveshaft from some ware
Trevor
Gear box output shafts
Re: Gear box output shafts
Trevor,
Output shafts and the side cover flanges are different for hardy-spicer and rubber coupling.
If you would like to swap your hardy-spicers for a full set of rubber output shafts and side covers, 2 x NOS rubber couplings, and driveshaft end let me know, as I need to convert a box from rubber to hardy-spicer outputs.
