Afternoon all. I'm having a few issues at the moment with DPU's ignition system. Would I be able to replace the 850 dynamo with the spare 1275 unit I have? Secondly, on the voltage regulator, is the middle back spade connector empty or does it have the smaller yellow wire attached? I don't want it to have a melt down or worse!
Dynamo issues
- Been thanked: 10 times
Re: Dynamo issues
The 850 & 1275 Dynamos are the same. Not sure re wiring as I don't have a reference to hand at work.
Full wiring diagram here.
http://mk1-performance-conversions.co.u ... l_1968.pdf
- Rich997
- snoopy64
- Has thanked: 92 times
- Been thanked: 14 times
Re: Dynamo issues
Hi
I can recommend the electronic regulator conversion...
http://www.dynamoregulatorconversions.com/
Kevin
Kevin
