rear subframe
- slowboy
rear subframe
hello guys, please can someone jog my my memory as to pointers for identifying a proper rear subframe, am i right in remembering the captive nuts for the radius arms should be hex not round for example, have a few to go at but they all different , had problems before and dont want them again
many thanks
- Been thanked: 41 times
Re: rear subframe
A proper or genuine if you mean that , has a mowog logo reverse pressed into the subframe ... Ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
Porsche 997 turbo S
I am from Essex
- slowboy
- Has thanked: 206 times
- Been thanked: 80 times
Re: rear subframe
Maybe it was the Aust Production? but our subframes had square nuts welded in fro the radius arm brackets and didn't have mowog pressed in to them but were stamped.
- slowboy
Re: rear subframe
that is what I have, it looks to be thicker material and the radius arm mounts line up with the brackets, it isn't stamped mowog though, still think its a better option than another couple I have that have no pressings and the mounts are not as in line as the other, thanks spider, am going to go with what I thought was the nearest to a mowog frame as I remembersquare nuts welded in fro the radius arm brackets and didn't have mowog pressed in to them but were stamped.
- pad4
- rich@minispares.com
Re: rear subframe
Where can I subscribe?rich@minispares.com wrote:I bet you where a subscriber........pad4 wrote:Knickers - Love it !!!![]()
- slowboy
