Painting engines
gs.davies
Has thanked: 75 times
Been thanked: 77 times
Painting engines
Post by gs.davies »
Any tips on paining the engine? Brush vs Aerosol vs getting a compressor and thinning it and spraying it?
Been thanked: 10 times
Re: Painting engines
I have used brush, aerosol & sprayed using a compressor. Best results were achieved using aerosol. Main thing is to make sure that the whole thing is as free from oil as humanly possible. Then a give it a good few coats or it will drop off.
gs.davies
Post by gs.davies »
Daft question but do they usually need a primer coat or do the engine paints go straight on?
I always put it straight on. M
dklawson
Post by dklawson »
Thoroughly degrease the engine (multiple times). Allow the block to completely dry. Primer is optional. I typically haven't bothered to use it.
I brush paint blocks and spray smooth items like valve covers and sheet metal bits.
Doug L.
Post by Old English White »
dklawson wrote:Thoroughly degrease the engine (multiple times). Allow the block to completely dry. Primer is optional. I typically haven't bothered to use it.
I've generally done the same. I did use a primer on the rocker cover before I sprayed I sprayed that with engine paint but I'm sure BMC never bothered! I just didn't want brush marks to show on the rocker cover.
abri
Post by abri »
Can one get a decently smooth finish on a clutch housing using a brush?
Gareth Brandt
Post by Gareth Brandt »
Aerosol no primer :)
That looks pretty much perfect Gareth!
