Dynamo problem?
coopertim
Location: In the garage spending far more time and money than my wife agreed to! Lincolnshire UK
Has thanked: 45 times
Been thanked: 15 times
Dynamo problem?
Post by coopertim »
Morning all, how do I tell if the dynamo has had it? Whilst the car was in for MOT the workshop charged the battery and the car started on the button no problem. The last few times starting though it has seemed as if the starter motor has stuck and won't engage but the car starts by bumping straight away. I took the starter motor off yesterday and lubricated it but the problem is still there with the power running down. I've took it on a fairly long run but it makes no difference - switch off and it refuses to turn over.
Dynamo had it?
Cheers. Tim
coop12g295
Re: Dynamo problem?
Post by coop12g295 »
My first check with it running,put voltmeter on battery and you want to see approx. 13,5 volts
Daz1968
Re: Dynamo problem?
Post by Daz1968 »
Easy test is to remove it from car apply earth to body and connect live to both terminals, should spin up as a motor if it does this problem is likely with control box. There is a guide on this site somewhere with test procedures
Simon776
Re: Dynamo problem?
Post by Simon776 »
If the ignition light goes out that usually indicates all is well with dynamo. Have you checked that the battery isn't being over charged?
I'd also check the engine earth strap and stater solenoid.
coopertim
Re: Dynamo problem?
Post by coopertim »
Many thanks for the replies!
Simon, the ignition light stays on even when revved so i would say that theres a good chance the dynamo needs attention!
Daz1968
Re: Dynamo problem?
Post by Daz1968 »
My ignition light stayed on, dynamo was fine it was just the points in regulator box needed a good clean. There are a few videos on YouTube from moss Europe that explain how the system works but all you need to test it is a basic voltmeter
LarryLebel
Re: Dynamo problem?
Post by LarryLebel »
Could be a bad battery. Have it load tested.
Andrew1967
Re: Dynamo problem?
Post by Andrew1967 »
More likely to be the regulator than the dynamo, as mentioned previously.
But...never say never !
InimiaD
Re: Dynamo problem?
Post by InimiaD »
Might be worth checking the springs holding the brushes (in the dynamo) are intact. I had the same thing happen to one of my old Minis and I found one of the springs had rusted through.
