Been searching for ages, but cant remember what they are called...can some one help please ?
I believe someone makes those floating nuts things that the factory used for some assembly reason.
Any idea please ?
Floating nut things in the floor
- mab01uk
- Has thanked: 262 times
- Been thanked: 231 times
Re: Floating nut things in the floor
Floating caged nuts are used in mechanical production to allow for wider tolerances when assembling two components while lining up threaded fasteners. If the nuts were welded or riveted in position the alignment would need to have a smaller tolerance and manufacturing components to tighter tolerances increases their cost.
- Exminiman
- Has thanked: 58 times
- Been thanked: 57 times
Thanks folks, will give MM a call, I had in my mind they had a specific name, but maybe not.
- MiNiKiN
- Has thanked: 95 times
- Been thanked: 31 times
They are also called 'captive nuts'
