WTH??!?! Have you seen this item on ebay.
mini_surfari
Re: WTH??!?! Have you seen this item on ebay.
Post by mini_surfari »
MrNoo wrote: Tue Apr 04, 2023 6:10 pm
IanD1965 wrote: Sun Apr 02, 2023 9:25 am
251 ENG wrote: Wed Mar 29, 2023 8:31 pm Purchasing a set of steel caps from swiftune plus the cost of good line boring will prove a shock to your wallet!
I have had this done. It cost an extra £700 to machine the thrust surfaces in apparently🙄
This was on top of the line boring and initial £300 for caps and bolts. Does that sound about right?
Think mine was 1800, that was to drill the extra two hole for centre main, we also had to move the crank up toward the deck as it had suffered a nasty on the centre main. Line bore and hone and thrust faces machined. It is not an easy job to get spot on and I wouldn't be trusting just any old engineering shop to do it, ideally one that has done them before. Also had an overbore, cam bearings and just faced the block, drill out/tap the gearbox bolt holes and tap oil gallery holes to accommodate brass tapered cap inserts, so easy to remove to clean in event of a rebuild. Obviously the latter stuff is on top of the line boring etc price
Who does your machining? You're not far from me.
IanD1965
Post by IanD1965 »
Who’s not far from you ?
MrNoo
Post by MrNoo »
mini_surfari wrote: Wed Apr 05, 2023 2:03 pm Who does your machining? You're not far from me.
South Cerney Engineering, but they are very expensive, had some very short inlets that I made up for twin 40's on my Arden head, angled and splayed needed facing and got stung for 360 inc vat. In their defence they did have to make a jig to hold them and also wanted a bit more off one side of a face to angle the carbs down a tad more. But saying that they do a very good job. I have used them for nearly 30 years and never had an issue (bar the price on occasion!)
imack
Post by imack »
Recently had similar block "race prep" carried out by KAD which included supplying and installing steel caps/4 bolt centre, line boring and thrust facing, offset boring, drill and tap for 11 stud an 5/16 gearbox bolts, drill and tap for screws in oil gallery bungs, semi dry deck and deck 30 thou, replace cam bearings.
£1500
Pete
Has thanked: 59 times
Been thanked: 149 times
Post by Pete »
Yet another fine selection of altered logbooks recently upgraded with a biro to now read Cooper from the same seller as all the others :
rolesyboy
Has thanked: 19 times
Post by rolesyboy »
It’s such a gutter like thing to do isn’t it.
Grown men pulling naff stunts like that is just embarrassing
Duplicate
Also fraudulent … but wonder which is more so, him trying to con someone or someone using it to (try to) obtain an identity.
Has thanked: 150 times
Been thanked: 137 times
SURELY, someone with a bit of nouse or authority somewhere could have been clamping down on this. Or am I missing something.
I'd nbe thinking something along the lines of ''''pecuniary advantage by deception.....'
Pete
Post by Pete »
rolesyboy wrote: Mon Apr 10, 2023 3:43 pm It’s such a gutter like thing to do isn’t it.
Where there’s muck there’s brass and looks pretty lucrative to me!
woodypup59
Has thanked: 9 times
Been thanked: 23 times
Post by woodypup59 »
Ive heard it said that DVLA monitor this sort of stuff on Ebay, and void any that they can trace off the computer system.
Catmint
Been thanked: 20 times
Post by Catmint »
Peter Laidler wrote: Mon Apr 10, 2023 4:24 pm Or am I missing something.
I think it is the people who buy them that are missing something - who in their right mind would expect to get a new V5 from something like that
trevorhp
Has thanked: 16 times
Post by trevorhp »
Just thought about a possible explanation,apart from the obvious clutch of idiot customers.
If you have a body shell or complete car that is post '66 and you need an identity for a pre-'66 car but don't actually need a V5C which I presume you don't need for an HTP, maybe a cheap buff logbook would do the trick.
Just trying to rationalize this odd set of circumstances.
Doesn't seem to make much sense otherwise.
T
KDK 320F
HDK 443E
DJJ 226H
TFD 47G
PKV 375
1 x chassis 007 1967 Cox GTM
Richspec
Post by Richspec »
Can anyone critique these two for me please? a friend is looking for a second mini and wants something older.
https://www.ebay.co.uk/itm/125753463452 ... 58eDMvQJUs
and
https://www.ebay.co.uk/itm/325605621502 ... 7ogXf5HVO0
apologies if they've been discussed already but gone back a bit in the thread and not seen it.
ta
Rich
steve1071
Has thanked: 18 times
Been thanked: 17 times
Post by steve1071 »
That MK3 looks lovely!
Pete
Post by Pete »
Our favourite dodgy logbook dealer has hit a pretty productive seam recently, this one’s been altered (as usual) to read 1275 Cooper S. Like shelling peas! If peas were £250 a pop.
'S'-type
Has thanked: 39 times
Been thanked: 15 times
Post by 'S'-type »
Pete wrote: Wed Apr 12, 2023 4:47 pm Our favourite dodgy logbook dealer has hit a pretty productive seam recently, this one’s been altered (as usual) to read 1275 Cooper S. Like shelling peas! If peas were £250 a pop.
Likes his black ink doesn't he? Schoolboy quality forgery.
He's taking the piss.
'S'-type wrote: Wed Apr 12, 2023 7:44 pm
I'll second that !!
I bet its someone known in the Mini fraternity too.
MrNoo
Post by MrNoo »
'S'-type wrote: Wed Apr 12, 2023 7:44 pm Likes his black ink doesn't he? Schoolboy quality forgery.
To be fair it's no different to what some of the Mini Cooper Register reps do with sales projects, certainly one springs to mind
