Serck RH tank ?
KennethDK
Serck RH tank ?
Post by KennethDK »
Hi guys
Does any of you know this right hand tank? I guess Serck SMS stands for Serck Sheet Metal Services
Regards
Kenneth
Austin Mini Cooper mk1 1962 - rallycar
Morris Mini Deluxe mk2 1968 - daily driver
http://www.miniteam.dk
mk1rally
Re: Serck RH tank ?
Post by mk1rally »
Yep, looks just like mine and I was told that it was.
Etienne B.
Re: Serck RH tank ?
Post by Etienne B. »
Hi Kenneth,
My Serck looks slightly different to yours,most notably the plate with a serial number which doesn't show the SMS letters.
The plate is also fitted in a different place.
Hereafter two pictures that are the only one I have at hand.
the fitment appears to be slightly different too ...
Toby
Has thanked: 11 times
Re: Serck RH tank ?
Post by Toby »
Serck was one of the first companies to manufacture right hand tanks. If you ordered one from BMC as a option for you mini it would have quite likely been one done by them.
T.
foggy
Re: Serck RH tank ?
Post by foggy »
The same company that makes oil coolers ?
KennethDK
Re: Serck RH tank ?
Post by KennethDK »
Thanks guys. The tank is not mine (yet), but I'm looking to buy the one in the pictures :D
Regards
Kenneth
Etienne B.
Re: Serck RH tank ?
Hi Kenneth,
There should be a serial number on the manufacturer plate,
would be interesting to compare with mine,
"Yours" looks more recent, if not more elaborate in terms of welding, etc.
Until later,
Good luck,
Etienne
KennethDK
Re: Serck RH tank ?
Post by KennethDK »
Sorry for my late respond to your post.
Regards
Kenneth
Goldbrocade_62
Re: Serck RH tank ?
Post by Goldbrocade_62 »
You've gotta love the build quality
