Speedwell Rev-Counter
jsilv
Post by jsilv »
Anyone knows how to connect this Speedwell Rev-counter?? :D
Thanks,
1972 - Morris Mini Clubman MKII - "Portuguese CKD Build"
Been thanked: 10 times
Re: Speedwell Rev-Counter
I don't have the details for those late ones.
Sorry,
jsilv
Post by jsilv »
mk1 wrote:I don't have the details for those late ones.
Sorry,
Thanks, so this a late version, it has 2 wires connection :roll:
It's a very late one.
Were still available new in the 80's.
jsilv
Post by jsilv »
mk1 wrote:It's a very late one.
Sourcing in the internet, the only that uses 2 wires connection. :?
jsilv
Post by jsilv »
Any ideas? Anyone using one? otherwise is useless... :cry:
iain1967s
Been thanked: 7 times
Post by iain1967s »
Is it sealed, or can you dismantle to separate the gauge from the pod?
More might be learned from photos of the internal layout and design.
Exminiman
Has thanked: 54 times
Been thanked: 52 times
Post by Exminiman »
Think you just put in inline on the positive coil wire, you will then see if it works or not :?
jsilv
Post by jsilv »
iain1967s wrote:Is it sealed, or can you dismantle to separate the gauge from the pod?
It is sealed... i never saw one with only 2 wires, unless it uses the back metal support, as ground... :?
jsilv
Post by jsilv »
Exminiman wrote:Think you just put in inline on the positive coil wire, you will then see if it works or not :?
It could be, with back metal support as ground, who knows??? :cry: :?
Exminiman
Post by Exminiman »
In your first picture there is a two bladed connector attached to the body, this is most likley the earth.
Just wondering if the counter has a light and is so where is the bulb holder
jsilv
Post by jsilv »
Exminiman wrote:In your first picture there is a two bladed connector attached to the body, this is most likley the earth.
The two bladed connector is the bulb holder for the light, and both the holder and interior support is plastic, no metal. So i discarded the possibility of some connection through the support.
jsilv
Post by jsilv »
It works!!! After "zooming", one photo that i found in some ebay ad :lol: :lol: :lol:
- the red wire to positive terminal of ignition coil;
- the black wire to negative terminal of ignition coil;
in other ebay ad, the seller say that "This tacho is not polarity sensitive" :D
unfortunately i cant read the all warnings in the photo :lol: :lol: :lol:
l) about positive earth installations, with is not my case, one less :lol:
the h) and i) can be a problem :lol: :mrgreen:
the "Note" is something like this: "this tachometer will not be damage if momentary miss connection but is .... wrongly connected it will read incorrectly and eventually its eletronic components may be destroyed." :D
Glad you got sorted.
jsilv
Post by jsilv »
mk1 wrote:Glad you got sorted.
Just another question :D , with this oil guage whats is needed for installation? I suppose that you already install a fews :mrgreen:
this?
http://www.minispares.com/product/Class ... 0to%20shop
Thank You!
