Firestone/BRM Correct Wheelnuts?
Posted: Sun Jun 22, 2014 2:31 pm
by amadcitrus
Hi, I hope someone can help,
I've got a set of the ones on the right in the attached image,
Anyone had any experience with these wheels? I'm guessing they will want some special sleeved nuts, but I can't find a definitive answer on the web for what ones exactly.
I measured the internal diameter of the stud holes through the wheels as close to 13mm, but the outer diameter on most sleeved nuts seem to be larger than that.
If I can avoid it, I'd rather not go down the route of having to expand the holes in the wheels.
Any advice greatly appreciated, thanks.
Re: Firestone/BRM Correct Wheelnuts?
Posted: Sun Jun 22, 2014 8:55 pm
by BRI MK1
Have a look at the speedwell wheels as there was a link with brm , I have a set of speedwell wheels the washers are attached to the nuts hope this helps cheers Brian.
Posted: Mon Jun 23, 2014 7:28 am
by Old English White
I had a set of those BRM 5inch alloys on a Mk1 Mini Cooper some years ago. The wheel nuts were chrome plated and rather weak (I broke one or two!) and never managed to obtain correct replacements. I think they did indeed have a washer attached. Lovely wheels, very distinctive, and all the years I owned my car I only ever saw one other set, so quite rare!
Worth persevering with. Sorry I can't be more helpful.
Posted: Tue Jun 24, 2014 3:19 pm
by surfblue63
I went to these guys when I needed some nuts for my original D1s.
http://www.speedshack.co.uk/Wheelnuts.htm
Posted: Tue Jun 24, 2014 4:56 pm
by LDR209H
Thanks for the link Surf. Got a set of GKN's (as per Lotus 47) with the same issue.
