alloy heads....
mini63
alloy heads....
Post by mini63 »
a few interesting pics from one of my old tuning books...and I like a good cutaway too.
AndyB72
Re: alloy heads....
Post by AndyB72 »
Think I've got that book somewhere.
Bought some 40s earlier this week for the Speedwell 7 port, this seemed like a good thread to add some quick mockup photos, its a bog old unit with the carbs on...
Re: alloy heads....
Whoever restored that Speedwell 7 port looks to have done a beautiful job :lol:
rich@minispares.com
Re: alloy heads....
Post by rich@minispares.com »
those manifolds look a bit special!
Re: alloy heads....
They were originally made for 4 semi downdraught AMALS, but have been modified for 40's.
Not the tidiest job ever, but functional.
m1cH1
Re: alloy heads....
Post by m1cH1 »
May I ask which book this is? The cutaways look really nice!
Cheers, Mike
mk1coopers
Re: alloy heads....
Post by mk1coopers »
I'm guessing with that set up there's definitely going to have to be a few bulkhead tweaks needed on a Mini :P
rich@minispares.com
Re: alloy heads....
mk1coopers wrote:I'm guessing with that set up there's definitely going to have to be a few bulkhead tweaks needed on a Mini :P
both bulkheads looking at the length of those inlets! :lol:
AndyB72
Re: alloy heads....
Post by AndyB72 »
Would def make in-car setting up of the carbs dead easy from the passenger seat :)
At some point I'm gunna see if Maniflow can make another pair of manifolds.
mascher
Re: alloy heads....
Post by mascher »
The book is "The Design and Tuning of Competition Engines" by Philip H. Smith. There are about 5 editions from 1954 to 1971 as far as I know. I have a 1974 printing of the 5th edition so there may be more. Published by Robert Bentley.
My copy has the same pictures on the same pages as the original post.
Kelley
rpb203
Re: alloy heads....
Post by rpb203 »
Is it possible to post a shot or 2 of the rest of the Speedwell 7 port, in particular to the inlet ports on the head, are these two thin oval shapes with a very thin strip of metal between each one? Similar to the Manx 7 port but with the separation of the inlets in the head and not the manifold?
I believe that the head was originally run in an A40?
Re: alloy heads....
You are right on all counts, 4 long thin inlets. the head was originally designed for use on an A40.
rpb203
Re: alloy heads....
Post by rpb203 »
Excellent thanks, I don't think that they made many of them, probably just a handful? good that there are 2 together! I believe that Roger Bunting used to race an A40 with one of those fitted?
Not sure how well they worked?
