Relay help.....Lucas 6RA
Clappy
Post by Clappy »
Hi,
My mini is in the process of its restoration, and will end up a works (ish) replica.....with twin spot and fog lamps on a works lamp bar.
My question :
Is a 12v / 20 amp Lucas 6RA relay capable of handling these ?
The relays I got with the wiring kits i bought are 40 amp. I plan to run a separate relay for each pair of lamps (switched and working on "flash" from the column).
Jon
Lord Croker
Re: Relay help.....Lucas 6RA
Post by Lord Croker »
Hi Jon,
1 X Lucas 6RA per pair of lights, in my experience works fine, it was the set up I had on my rally car & never gave any problem, but a word of caution, if you plan to use 100 watt bulbs, it might be pushing the limits!
Regards, Rich.
Clappy
Post by Clappy »
Lord Croker wrote:Hi Jon,
Regards, Rich.
Thanks Rich,
I've got 2 Lucas Ranger Spots and 2 Ranger Fogs, I think they are both 48w bulbs....so based on your experience, should be a problem !
Jon
pad4
Post by pad4 »
Make sure you get the correct 6RA relays as you can get open and closed versions
Pad
Clappy
Post by Clappy »
pad4 wrote:Make sure you get the correct 6RA relays as you can get open and closed versions
Pad
They are the open ones (SRB111). I hope to have them wired up on the switch and main beam (if i can get my head round it !).
Jon
sr001
Post by sr001 »
I run 2 Lucas 700 lamps with uprated halogen bulbs through a single 6RA relay with no problems at all. Max current draw with two 55w bulbs is under 10amp, two 100w will be under 17amp. Plus I always fuse the main feed anyway.
