Odd noise...
Posted: Thu May 29, 2014 9:25 pm
by tedmcedd
My Austin 1300 is making an odd noise...
Engine idles well, and sounds sweet when revved.
However...
Driving it seems to make a whirring clicking noise.... Like when you put cards in your bike spokes as a kid....
Only seems to make the noise at 30mph or above, regardless of what gear you are in....
Any ideas!?
Bearings are recent.
Ed
Re: Odd noise...
Posted: Thu May 29, 2014 9:55 pm
by Dr S
Worth checking if clutch up, clutch down makes any odds.
My fest guess would be broken up rubber couplings in the drive line. They make some funky rubbing sounds in my experience
Re: Odd noise...
Posted: Thu May 29, 2014 10:02 pm
by Chalkie
Or check wheel bearing or even a CV joint
Re: Odd noise...
Posted: Fri May 30, 2014 9:45 pm
I had one like this for nearly a year (I don't drive it too often) and after changing the wheel bearing (which looked OK), checking everything else while I was there, about 8 months ago, to no avail, I found the one of the welds on the rim had a crack in it.
Re: Odd noise...
Posted: Fri May 30, 2014 9:56 pm
by davidnutland
Plastic fan hitting something?
Re: Odd noise...
Posted: Fri May 30, 2014 10:51 pm
by tedmcedd
Interesting ideas guys!
Won't be the clutch or fan, as the noise isn't there when the car is still and idling, or still and being revved...
The rubber x's have been replaced recently, along with the bearings... I'll check the cvs next... And the rims!!
Ed
Re: Odd noise...
Posted: Fri May 30, 2014 10:57 pm
by IAIN
If its a light clicking noise......... Speedo or the cable ?
Re: Odd noise...
Posted: Sat May 31, 2014 9:20 am
by tedmcedd
I did wonder the speedo gears, but if you have the window down, you can hear it outside the car....
Re: Odd noise...
Posted: Sat May 31, 2014 9:50 am
by IAIN
If its got hub caps on it try taking them off, they can creak.
Mybe the wheel nuts are loose inside the hub cap....................
